#Camaro6
Old 03-25-2019, 02:33 AM   #1
jeep_junkie
Drives: 2000 Trans Am M6
SS 1LE clutch chatter/shudder
Is this a normal thing? My car's done it since the day I drove it off the lot with 9 miles on the clock. I thought it might disappear with time but nearly 13k miles later it's still there. The clutch chatters/shudders on engagement unless I let it out at really low RPMs or let it out aggressively. I know it's not my driving style - been driving manuals since the day I started driving.
2018 - 1SS - 1LE - Red Hot
jeep_junkie is offline   Reply With Quote
Old 03-25-2019, 04:59 AM   #2
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
I don't recall chatter on mine, I feather the clutch til the tipping point.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 03-25-2019, 06:44 AM   #3
CamaroChriSS
CamaroChriSS's Avatar
Drives: 16 1SS M6 Black -previous 00 Z28 M6
I'm in the same boat, although mine has gotten a little better over time it's still there unless I crawl or gun it - and been driving stick for over a decade so I'm fairly certain it's not me.
CamaroChriSS is offline   Reply With Quote
Old 03-25-2019, 07:12 AM   #4
TheBusDriver
TheBusDriver's Avatar
Drives: 2016 2SS (M6)
I sometimes get the same thing. I try to avoid the load/clutch engagement point where it happens of course, but it seems like where that shutter happens is about exactly where I'd want to actuate the clutch/throttle. 30k miles now.
Mine isn't that bad, you can feel it in the pedals and a bit in the seat occasionally.
For reference, I have a full bolt on Subaru with aftermarket clutch/lightweight flywheel, and when the clutch gets warm (driving in traffic) the chatter is horrendous to the point it feels like there's a 7.0 magnitude earthquake occurring. Never had an issue on the stock Subaru clutch.
TheBusDriver is offline   Reply With Quote
Old 03-25-2019, 07:30 AM   #5
Jsreo
Drives: 2017 2SS Manual
I have ~ 23K on mine and have never experienced any shudder whatsoever.
Clutch engagement is very smooth and easy to modulate
Jsreo is offline   Reply With Quote
Old 03-25-2019, 08:18 AM   #6
Infamus
Infamus's Avatar
Drives: 2018 Camaro ZL1
My 19 has none that I have experienced as of yet. I do tend to drive her like I stole her rofl...
Infamus is offline   Reply With Quote
Old 03-25-2019, 08:30 AM   #7
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
Is the clutch in the 1LE different from the non-1LE SS? Regardless, no chatter with my 1LE. Original owner, straight from the factory.
Nigel
Whitespeed is offline   Reply With Quote
Old 03-25-2019, 08:35 AM   #8
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
I experience it on occasion as well. Like thebusdriver said, there is a certain point that seems to cause it more often then not.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 03-25-2019, 09:59 AM   #9
Laststandard
I've heard the twin disc can make a little more noise. I can notice a bit of noise with mine sometimes, but I've never had it shudder.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 03-25-2019, 11:53 AM   #10
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I get it sometimes, but when the car is cold.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 03-25-2019, 12:06 PM   #11
thrashergrant
thrashergrant's Avatar
Drives: 2018 Camaro SS 1LE
Hmm... I don't experience any shudder at high RPM.
If anything, I get a little of the "metal clunk" symptom with clutch engagement at low RPM's/parking lot speeds. Apparently that's normal.
thrashergrant is offline   Reply With Quote
Old 03-25-2019, 12:10 PM   #12
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Its from being a twin disk... mine has done it since new... 42K miles later still without issues. I've had plenty of aftermarket clutches on previous cars and they also sound like this... that chatter is due to the twin disk setup..
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 03-25-2019, 12:24 PM   #13
CamaroChriSS
That is a relief to know. Have been paranoid I was wearing the clutch prematurely.
Old 03-25-2019, 12:37 PM   #14
KCelsius
KCelsius's Avatar
Drives: 2018 Summit White 1SS 1LE
I've also noticed that I almost have to hold the clutch right at the engagement point as I'm doing a 1-2 or 2-3 shift in order to get it smooth or else if I do a normal gradual disengage and then step out, it feels like I just dropped the clutch.
I came from a 15' WRX and am disengaging the clutch the same way but I guess with the 1LE MT, it's a little different and I can't quite get the same smoothness.
KCelsius is offline   Reply With Quote
