06-18-2015, 01:06 PM | #1 |
Drives: 2011 SGM 1SS/RS M6 Join Date: Feb 2012
Any Tips - first run at polishing tomorrow
Going to be polishing up the green machine tomorrow to get out all the fine swirls from the prior owner/dealer cleanings. They are all fairly light swirls, but it'll make me feel better.
I'll be using a Porter Cable 7424 with a chemical guys blue pad (light polishing) and M205. The M105/205 combo seemed completely unnecessary since there are no deeper gouges in the paint at all, just light that can really only be seen in the correct lighting. I plan on following up with Chemical Guys JetSeal sealant - heard a few good things about it from a friend, and topping it off with a 100% carnuba wax. Process is going to be: Rinseless Wash with ONR (love living in an apartment complex) Clay Bar M205 w/ blue pad Rinseless Wash to clear off any polishing residue Jet Seal (2 coats) Carnuba I have heard of some people taping stuff off, and others never mention it. What would I tape off? just window trim/door handles? Any specific angles or areas on the car you think should be marked off? Any other tips or tricks I should be aware of?
Current: 2011 SGM Camaro 1SS/RS M6 - CAI Cold Air Kit, Janetty Tuned
06-18-2015, 01:10 PM | #2 |
Drives: 2015 Camaro RS 2LT AGM Join Date: Aug 2014
Just my opinion. I Tape off all plastic and rubber trim. Cause my plastic and rubber sealant reacts to wax leave a white haze. When you clay use a lot of lubricant to avoid marring. Good luck!!
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions) |
06-18-2015, 01:51 PM | #3 | |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
If you don't see correction you will have to step up to 105 and a heavier pad. Make sure you are going slow enough for the polish to work. Tape off plastic trim pieces to make polishing near those areas easier in the long run. Never polish in direct sun light. Have a few beers on hand also.
Detailing is an involuntary obsession.
06-18-2015, 02:21 PM | #4 | |
Thanks for the other tips as well!
06-18-2015, 03:26 PM | #5 |
ONR contains polymers which bond to the surface. I'd use an IPA mix after the clay bar just to be sure to remove any ONR, Old wax or sealant the clay bar didn't remove, and clay lube that's left on the surface, the cleaner the surface is prior to polishing, the better the polish and pad will work.
Edit. I shouldn't have used the word "cleaner", Naked would be a better word, the clearcoat has nothing on it that will come between your polish and pad. Wal mart sells 91% alcohol for around $2 a 16 oz bottle, mix with distilled water 50/50, they sell this for $1 a gallon. If you don't have a sprayer to put it in they also sell 32 oz sprayers for around $3. I would pick a section that has the most swirls, do your Rinseless, Clay bar, IPA wipedown in only that section, and then polish just that section. If your results are satisfactory, continue. If not as already mentioned you'll need to go more aggressive. No sense to prep the whole car if the pad/polish isn't getting desired results. I would drop the ONR before sealant and replace with IPA wipedown as well. Last edited by Joe M 2012 2SS; 06-18-2015 at 03:36 PM. |
06-18-2015, 03:28 PM | #6 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
beer or advil before you begin. depending on your preference.
06-18-2015, 09:35 PM | #7 | |
06-19-2015, 12:20 AM | #8 |
H-Town Camaro Club
Drives: 2010 ABM 1SS/RS, Red 85 Z28 Join Date: Feb 2013
FYI, when using a machine to polish, be very careful of the edges as you could burn through your clear coat and paint.
AGP Twin Turbo, RPS Triple Carbon Clutch, ZL1 Diff with 3.73 gears and Kooks 3" Stainless Steel Exhaust with X Crossover, Kooks Stainless Steel Mufflers, Go Fast Bits EBC, AEM Methanol injection and AEM gauges UEGO and Fuel pressure, Livernois's dual fuel pump, KB Boost a Pump, AUS 1000cc injectors, Full BMR suspension with Koni shocks, JDP Color Changing Halos, Color Changing Scanner Light Bar and Rockford Fosgate T Series Amp's Kicker L7 Sub's.
Build Thread: http://www.camaro5.com/forums/showthread.php?t=400372 |
06-19-2015, 06:56 AM | #9 | |
I like teeth.
Drives: #198 Join Date: Oct 2009
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
06-19-2015, 10:53 AM | #10 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
After my first polish job I took note of everything I should have done differently and posted the list. You can give it a look here:
http://www.camaro5.com/forums/showthread.php?t=399000
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
06-19-2015, 04:04 PM | #11 | |
I have always been curious of the actual benefit of it, as the only prior use of IPA for me was when I worked compounding creams and ointments. It was used for sanitization of blending tanks, pumps, hoses, packaging equipment, etc. after they had gone through a validated cleaning process. I'm sure being in Dental Medicine you are aware of the process of validation, I'm not sure car products or chemicals used to clean are actually put through the same process. I have just used this based on recommendation of professional detailers. However I do trust your opinion, or in this case could be fact instead of conjecture. (Did you do a swab test or something similar on a panel wiped down with IPA that had wax/sealant on it to determine if it had been removed?) I certainly wouldn't want to give anyone bad advice, but being so many pro's support this method, I figured it had to be beneficial. I have used it religiously, but I don't have any concrete proof (scientific testing) that it actually does what's suggested. I also realize many supported Dawn wash for strip wash, and through your tests you were able to determine that it actually doesn't remove LSP's. So if you have tested it, and have the proof that it does not remove sealants or wax, I'd remove it from my normal use before polishing, and before LSP. |
06-19-2015, 04:13 PM | #12 | |
I like teeth.
Also, I don't think it's bad advice, just unnecessary. It won't make a difference. I have tested whether it removes wax or sealant and that answer is no, it does not. Is it possible that it removes a little from the surface, sure. But does it remove it all, the answer is no. IPA can not reasonably be used to clean a surface entirely of wax or sealant.
06-19-2015, 05:34 PM | #13 | ||
I do find it hard to believe that Larry Kosilla, who does all his own compounding for his line of products, his wife is also a chemist I believe, would advocate it's use as explained here at the 5:00 point of this video. Also mentioned at the 7:42 point of this video of the Kevin Brown method, with Kevin Brown. https://www.youtube.com/watch?t=10&v=QG65GC5LOzw KB has been doing paint correction for 30 years now, and it's hard to believe he would do an "unnecessary" step. Last edited by Joe M 2012 2SS; 06-19-2015 at 05:45 PM. |
06-19-2015, 05:48 PM | #14 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Try not to use to much product.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
Thread Tools | |
