01-13-2018, 05:38 PM | #1 |
cleaning out head bolt holes
Gun cleaning kit. Best thing Ive ever used to clean out the head bolt holes. Your life hack for the day.
01-13-2018, 06:09 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
goin with studs? I always give the bolt holes a little spritz from the air hose holding a rag over it so crap doesn't blow in yer eyes....
now about those heads....heh heh..
01-13-2018, 06:44 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
Since he went with a TSP cam and said the valve angle is 13, must be a set of PRC 260's I would guess.
01-13-2018, 06:57 PM | #4 |
Drives: 2011 Camaro SS Join Date: Feb 2017
What caliber is a head bolt hole?
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
01-13-2018, 07:24 PM | #5 |
.44 S&W American baby!
01-13-2018, 07:30 PM | #6 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
This ought to come in handy here soon! Guessing my .45 caliber tips work great
01-14-2018, 01:38 AM | #7 |
Drives: Camaro Join Date: Dec 2009
I bought both sizes of the ARP thread chasers. You would be surprised of what came out from the factory.
01-14-2018, 05:12 AM | #8 |
I make my own chaser. Factory bolt does a real good job once I take a Dremel with a cutoff wheel and cut slots in it down the threads. And yes its nasty lol.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X Last edited by Bo White; 01-14-2018 at 04:10 PM. |
01-14-2018, 06:53 AM | #9 |
The M11x2.0 tap from ARP is around $53 bucks, WOW.
01-14-2018, 10:33 AM | #10 |
make sure you use the ARP lube properly(no this ain't a sex joke!) it should only be used between the nut and washer...otherwise it WILL throw your TQ off...if any gets between the washer and head the washer will turn too and cause over TQ'n..
01-14-2018, 01:12 PM | #11 |
Correct. I put the washers on a piece of plastic and rub the moly lube on them then slip them onto the bolts/studs.
01-15-2018, 10:30 AM | #12 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Biggest waste of money ever. I do same thing as Bo does above... works same as the ARP chaser.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
01-15-2018, 09:59 PM | #13 | |
Them holes are so dirty the block can crack if you do not clean them out. |
01-16-2018, 04:34 AM | #14 |
Drives: 13' 1LE Join Date: Apr 2012
The gun cleaning kit!! Wow that is a serious time and effort saver!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
