Old 03-04-2021, 06:42 AM   #1
Camaro227
Camaro227's Avatar
Drives: Toyota Puris
How to check oil pressure without gauges?
Curious to see if there is a way to check the oil pressure without the gauge pack? (Talking about the optional gauges in the center console area)
Thanks
Camaro227 is offline   Reply With Quote
Old 03-04-2021, 09:11 AM   #2
Risingson05
Risingson05's Avatar
Drives: 2015 zl1
Thanks
Mechanical gauge
Risingson05 is offline   Reply With Quote
Old 03-04-2021, 11:26 AM   #3
ariZona28
ariZona28's Avatar
It is displayed on the DIC page. And as mentioned you can use a mechanical gauge. I'm currently learning my recently purchased C5 Vette with an LS3 transplant and the OP sending unit is on the AFT side of the intake manifold, drivers side. You could connect a manual gauge in that location for trouble shooting purposes.
ariZona28 is offline   Reply With Quote
Old 03-04-2021, 02:17 PM   #4
Camaro227
Camaro227's Avatar
Interesting it's not displayed on my DIC....... Don't have that menu screen. 2012 SS
Old 03-04-2021, 03:03 PM   #5
Nate2SS
Drives: 2011 Camaro SS
I believe that's the new gauge cluster and new menu. With 2010-2013 models it seems like you're stuck to either putting the 2SS gauges for the middle console or buying an aftermarket gauge and hooking that up.
Someone correct me if I'm wrong though.
Nate2SS is offline   Reply With Quote
Old 03-04-2021, 03:23 PM   #6
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I have a 2012 SS and don't have that menu button but have the console gauges.
afm delete, GPI SS1 Camshaft with vvt, GM Performance Racing lifters, Comp CAMS trunnion upgrade, TSP Chrome Molly pushrods, TSP polished .660 valve springs, Melling 10355HV oil pump, Cold Air Inductions cai, TSP 1 7/8" longtubes with 3" exhaust
morepowerjoe is offline   Reply With Quote
Old 03-04-2021, 03:25 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Nah you're right. The 2010-2013's we don't have that option in our DIC, that's why I have the Aeroforce gauges, and watch my console gauges. At least not to my knowledge.
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 03-04-2021, 05:14 PM   #8
Camaro227
Camaro227's Avatar
I figured it out! I have a bluetooth OBD2 Scanner with the Torque Pro app. I input these values into the app:
You'll need to go to: Settings-Manage extra PIDs/Sensors-...-Add custom PID and enter the following values:
PID: 22115c
Long Name: Oil Pressure PID
Short Name: Oil Pressure
Minimum Value: 0
Maximum Value: 100
Scale: x1
Unit: psi
Equation: (A*0.65)-17.5
OBD Header: Auto
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
