Old 03-27-2021, 05:53 PM   #1
Camaro227
Camaro227's Avatar
Drives: Toyota Puris
Jerk when accelerating?
Camaro227 is offline   Reply With Quote
Old 03-28-2021, 09:51 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
What year is your Camaro?? I had this happening back after I bought it and it turned out to be the filter housing cracked and was causing a high pressure fluid spike in the trans and was fixed under warranty as there was a TSB out on the issue. Mine is a 2011..
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 03-28-2021, 10:45 AM   #3
Camaro227
Camaro227's Avatar
Thank you.
Old 03-28-2021, 10:50 AM   #4
Camaro227
Camaro227's Avatar
It's a 2012 SS. Do you happen. To have the TSB#?
Thanks
Old 03-28-2021, 01:34 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here you go sir, I found it. Mine was doing exactly what yours was doing and this is what they found when they took my pan off and checked the filter, it was split just like the first pic and there was a hole in it as well and they found tiny plastic pieces in my valve body and fluid, so they replaced EVERYTHING including the converter. Good luck..
https://static.nhtsa.gov/odi/tsbs/20...39489-5982.pdf
Old 03-28-2021, 02:40 PM   #6
Camaro227
Camaro227's Avatar
Wow that's strange. Thanks for the information. I won't be able to replace the all the parts due to no warranty .But I'll try to get it in sometime to drain the fluid and swap the filter.
Old 03-28-2021, 04:23 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
They only replaced all the parts because I had such a nice size hole in the filter and plastic was everywhere inside, so to be safe, and it was covered, GM just said to replace it all. Might only be that yours is only cracked, and if so and that was the issue, you will be good, if it fixes the issue you are having. The reason I think it had that pressure spike I was told was the pump was shimmed incorrectly, so that got fixed as well. Good luck and hope this was of help to you. Cheers..
Old 04-08-2021, 02:34 PM   #8
Camaro227
Camaro227's Avatar
Question
Okay, just got the fluid and filter changed. He gave me the old filter and everything looks good and the old fluid was cherry red. I will try testing it tomorrow and see what happens.
Old 04-08-2021, 07:30 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Cool, good luck.
Old 04-14-2021, 06:55 PM   #10
Camaro227
Camaro227's Avatar
Cool, good luck.
Alright think I finally got it! I got the fluid changed and it was shifting like garbage under wot. Come to find out the fluid was low... He topped of the fluid and it seems to be shifting great with no issues. So I'm thinking maybe the fluid from the factory wasn't quite enough.... That's what was causing the jerk.
Old 04-15-2021, 08:17 AM   #11
gtstorey
Circle D Transmission suggests 3/4 quart over fill.
https://www.circledtrans.com/files/R...-June-2013.pdf
Old 04-15-2021, 08:23 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, ^^^ this exactly. When they do a fluid change and fill it up to "their" specs, you will notice it a tad low, so adding a little more will make it shift better.
Old 04-15-2021, 08:24 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very cool!!! Enjoy that baby!!
Old 04-15-2021, 01:04 PM   #14
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
"Jerk when accelerating?"
Uhh...no, but to each his own. I'm too old and too married for all that...
ElderJ is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
