Old 10-20-2019, 04:58 PM   #1
TorchedLSX
TorchedLSX's Avatar
Drives: 2015 Camaro 2SS 1LE
Weak Starts?
Hey All,
I just picked up my 2015 2SS 1LE a little over a week ago. The previous owner recently installed a new battery. Every-time I start the car, it starts as if the battery is going dead or low.
Has anyone else run into issues like this? The car only has 37k on the clock so I would not assume its the starter going out already.
Thanks!
TorchedLSX is offline   Reply With Quote
Old 10-20-2019, 05:19 PM   #2
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
Check battery to make sure it’s good
Fred 6528 is offline   Reply With Quote
Old 10-20-2019, 05:27 PM   #3
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Google for Camaro Ground problems, that's the first thing I'd check. To frame, to engine etc.
These are notorious for camaro's especially that had CAI or headers installed.
silversleeper is offline   Reply With Quote
Old 10-20-2019, 05:28 PM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
These cars all turn over a little slow it seems. I charged up my battery because i thought it was dying. It started the same. Though mine is an 11. Might just be time to replace the battery for me anyway just due to time.
Greenhornet2 is offline   Reply With Quote
Old 10-20-2019, 05:37 PM   #5
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
That was my first thought too but if you go to you-tube and watch a dozen videos of these Camaros being started, you hear the same starting sound a dozen times. It's just what these cars do.
Danial is offline   Reply With Quote
Old 10-20-2019, 06:05 PM   #6
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
My car turned over slightly slow since I bought it...seems common.
Modernmusclecar is offline   Reply With Quote
Old 10-20-2019, 07:26 PM   #7
TorchedLSX
TorchedLSX's Avatar
Thank you all for the replies. The battery was changed maybe 2-3 weeks ago at a GM dealership. The car does have an aftermarket CAI (unknown brand), so I will check the grounds.
Thanks!!
Old 10-20-2019, 09:19 PM   #8
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Mine does it too. But the battery is still strong. I guess it's just a built in mod lol.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 10-20-2019, 09:37 PM   #9
mikeman
Banned
Drives: 2015 Camaro
Replacing the engine to body ground wire with a thicker cable will improve it. Had this problem with a Nissan I once owned.
mikeman is offline   Reply With Quote
Old 10-22-2019, 10:52 PM   #10
SimpleGreen
Drives: 2015 2SS/RS
I'd wager that one 'problem' is the battery being in the trunk. That accounts for a lot of voltage/amperage drop when running all the way back to the front of the car. All three of my Camaros turned over 'slightly slower' than my vehicles with front mounted batteries.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler
1993 C1500 Single Cab Stepside 5.3L LS Swap
SimpleGreen is offline   Reply With Quote
Old 10-22-2019, 11:04 PM   #11
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
Watching YouTube videos and since buying my car they all sound the same....sounds like a slow start, however, they just keep starting. Must be how they are.
I’ve owned 3 BMWs and all 3 had trunk mounted batteries....no similar slow start sound in the BMWs. Unique to the Camaros I think.
Black 6.2L SS is offline   Reply With Quote
Old 10-23-2019, 11:30 AM   #12
Leo72793
Drives: 2011 2SS/RS
Originally Posted by TorchedLSX View Post
Hey All,
Thanks!
I replace the factory ground wire with a better one under the hood and it made a massive difference on a nine-year-old battery, when I replaced it with an AGM it got even better.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 10-23-2019, 12:56 PM   #13
Greenhornet2
anyone who has changed this engine ground can you be specific on where the ground is on the engine and the chassis, also detail what size/type wire you used to improve it? It will be helpful for anyone wanting to help a slow start.
Old 10-23-2019, 03:31 PM   #14
mbesman
Great White
mbesman's Avatar
+1
mbesman is offline   Reply With Quote
