Old 02-21-2011, 10:11 AM   #1
Blue70SS
Blue70SS's Avatar
Wheel studs with more threads - solution I used
So here's the problem I had:
I purchased new Forgeline wheels and Bogart wheels - both could not achieve 9.33 turns of wheel nut that would put them at NHRA specs that require the wheel nut to be bolted on the diameter of the stud being used. Basically our 14mm wide studs use a 1.5mm thread pitch.... 14 divided by 1.5 is 9.33 threads being used to satisfy requirement. I'm only using the NHRA requirements as a safety benchline because that's what I've found and OEM wheels achieve this already - must be something behind it. As for if I'm using the correct studs and nuts IF I were a racer, I have not checked on - but might be useful info for others and welcome to this thread. I'm sure there are harder studs out there, but I wanted to make sure I wasn't replacing studs with ones that might prevent me from going back to OEM and readily available. Beside, our studs are already truck studs that torque to 150 ft lbs!
My fix is a spin off thread started by "blazzin1" Wheel Stud Problem... Thanks blazzin1!
http://www.camaro5.com/forums/showthread.php?t=124590
Now this fix does require modification to the studs I purchased and minor mod of front wheel knuckle casting - but I'm pretty sure an "allthread" version of the studs would have the same installation problems I encountered that required the slight modification. I did not complete this for my rear studs at this point since I gained 1.33 threads due to the rotors I'm using and am closer to the 9.33 threads needed (but might do later).
Please don't get lost in this part - it still applys to OEM part cars regardless. I have Racing Brake 2 piece rotors on all 4 corners. They are 4.5 lbs lighter on front rotors, and 6 lbs lighter for rears. The thickness of the center hubs on OEM rotors is 9mm, these are 7mm for wieght savings. So initially I gain 2mm of usable thread length. One small problem... aftermarket high end wheel makers are using very tight tolorances to clear the SS brakes. This 2mm difference took me down to ~.25mm clearance on my front calipers. Lingenfelter suggested I use a 1/8" spacer (3.175mm) and before anyone shoots down spacers, these are extremely thin and problem with big wheel spacers is loss of threads and additional torque on parts. This fix for me lost 1.175mm, which is .78 threads (turns of nut).
I used GM part# 11588810 which is from a 2004 Siverado 2500... probably other vehicles too. Our existing ones are #11588811 and measure 64mm total part length versus 71mm for Silverado studs. My finalized studs were all between 63 - 63.5mm total length (I began trying for 64, but then matched up to shortest one). I would suggest shooting for 63mm total length.
I ground off the entire area using 2 different wheels, 2nd one was finer. This could be done quicker probably by cutting off majority with a portaband or chop saw.
Removing the studs was easy. I was told one good hit on the stud with a small sledge hammer usually removes them. It took me about 2-3 lighter hits, but I didn't want to chance bearing damage, even though they hit them out with one hit all the time. To save my existing studs, I used 2 nuts on the threads and covered the stud end with an allthread coupler that had a bolt inserted. If you're tossing the old stud..... hammer away!
Next step is to use a wheel grinder to remove enough material to allow the modified stud clearance for installation. Grind, test fit, grind, test fit.... you get the idea. Only remove enough for installation. In my opinion the area removed seemed extremely safe and not a critical strength issue. I've seen much more modification on Jeeps that take a beating without any problems.
Now somebody my ask, "why not just remove the entire hub with bearing". I thought this would be crazy to have to do anytime a stud might need replacement, deal with rusty bolts, big vise, etc.
Installation of new studs was made easy with use of an air tool, 2 nuts and 3 big washers to draw the stud through.
Please ask questions if anything is unclear and I can update info.
Hope this helps someone.... Thanks again blazzin1 !
LPE Brotherhood
Old 02-21-2011, 10:12 AM   #2
Blue70SS
Blue70SS's Avatar
reserved for any additional info
LPE Brotherhood
Old 02-22-2011, 03:26 PM   #3
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
upgraded wheel studs, excellent find! I have done this nearly identical thing on every old pickup I have ever owned, quick and painless way to stay safe.
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 02-24-2011, 06:18 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
If you guys are looking for a less DIY solution we have just released our Extended Wheel Studs. They are 92mm in total length and provide an extra 19mm of thread over the stock lugs. Made from 4340 Steel Alloy for excelent strength, and feature a Teflon-Molybdenum for anti-galling and low friction.
Old 02-24-2011, 09:50 PM   #5
Blue70SS
Blue70SS's Avatar
Thanks, those will work great for the track guys! The bearing/hub assembly will need to be completely removed for installation or replacing single studs. Only drawback obviously is you can't use closed lug nuts for your dressy wheels. Are there also ones that are 62-64mm range that would still have about 3-4 more threads so could be a kinda dual purpose stud? (like mostly allthread version)
For road racing guys info and curiousity:
- Are open nuts required to visably see enough threads used?
- Is a certain type of hardness required beyond our OEM ones?
Got your solid subframe bushings installed yesterday.... alot easier than I first thought, and WOW do they feel good - no more wandering rear subframe!
LPE Brotherhood
Old 02-25-2011, 09:09 AM   #6
CYBER69
NEMESIS (NEMI-"SS")
CYBER69's Avatar
Drives: 2011 2SS-LS3, BLACK W/CYBER STRIPES
Rear Wheel stud Length question
Can you cut down the ARP wheel Studs? My problem is that I had Vaughn Machine section and extend my stock silver midnight wheels to 10.750 ( should of kept them at 10.5) so now with the 315 Dunlop will rub the inner wheel well. My fix was a 15mm (.590) hub centric spacer which should move the tire away from the inner well and provide a nice outer edge look. I want to keep the acorn style nut.... I thought it would be easy to get a stud with an additional 1/2 to 5/8 extension with no sucess. Looks like the only fix is a "ARP" 3" stud. Thats why I ask the question "can you cut them down or do you know of a better solution?
And when they say "Overall length" are they (stud manufactures) talking overall or from the inside of the flange?
1969 RS/SS Lemans Blue 396-350HP Convertible - Orig. Owner and 2011 RS/SS Black/Black Coupe - PFADT Stage-II, CAI, Richmond 4:33's, Barton Flat Stick-Short Throw, KOOK's ceramic LT's, Comp Stage II Cam, QuickTime cut-outs, Ryne Cunningham Custom Tune, Flowmaster, Heritage Grille, Eric Vaughn "widened" wheels w/ 315 Dunlops, MPD1 R.Spoiler & Dave Kahn "Buried" Cyber Grey Metallic Stripes.... 593HP / 517RWHP.
[SIGPIC][/SIGPIC]
CYBER69 is offline   Reply With Quote
Old 02-28-2011, 10:05 PM   #7
Blue70SS
Blue70SS's Avatar
Not sure how the stud manufacturers are stating lengths, but Pfadt would probably be more than happy to answer questions. Try calling them direct - they've been real helpfull. It sounds like they're comparing like measurements compared to my measurements..... "total length" and "additional threads over stock"
LPE Brotherhood
Old 03-01-2011, 02:55 PM   #8
PfadtRacing
When we posted our info total length refers to just that, the length from the bottom of the shank to the tip of the bullet nose. 19mm more usable threads constitutes a big improvement over stock and allows for more aggressive offsets and spacer combinations.
If you've got any more questions let me know!
Recommended Tire Sizes for 2010 Camaro Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 367 Yesterday 11:22 AM
Wheel Stud Problem.... blazzin1 Wheels and Tires Talk Sponsored by The Tire Rack 18 05-08-2015 06:43 AM
CHANGING THE STEERING WHEEL (Not for the faint of heart) VT2CA Camaro DIY & HOW-TO instructions & discussions 28 09-19-2014 02:31 PM
Rear Wheel Hub Removal....Help! blazzin1 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 02-15-2011 01:23 PM
repeated threads that pop up daily...... Ironheadspearo 5th Gen Camaro SS LS LT General Discussions 185 12-16-2010 02:38 PM
