04-21-2017, 02:00 PM | #1 |
Life Is Short Enjoy It!
Drives: Original Owner 15 Z/28 #934 Join Date: Sep 2016
Adding a Few Goodies to my Z/28
Well I have been accumulating a few things over the past few months and dropped the car off yesterday at my buddy's shop for install. Here is what is planned.
1. OEM Wickerbill 2. Brey Krause Harness Bar 3. Schroth 4 point Harness (drivers side only) 4. Zl1addons - tow hook mount front & rear 5. ZL1addons - Large front Rock Gaurds 6. Track Alignment and Corner Balance (using factory track spec) 7. Full fluid change (oil, trans, rear axel) - OEM recommended fluids 8. Castrol SRF brake fluid replacing stock fluid 9. Going to attempt to drop the stock seat height, or at least drop the front an inch or so. Already had clear film installed on front splitter, bumper, fenders, hood, mirrors behind front wheels to back wheels up to the seam 2/3rds of the way up the door and behind the rear wheels up to the bumper seam. Should be ready for track after this, now if I can just get some time to get there! |
04-21-2017, 02:46 PM | #2 | |
Drives: '21 ZLE A10 Join Date: May 2012
04-21-2017, 06:37 PM | #3 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
Supercup - can you elaborate on number 9? How will you do this?
Thx! |
04-21-2017, 09:06 PM | #4 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Also #6...not sure you can corner balance on the stock setup unless you add lead weights to the car.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
04-21-2017, 09:53 PM | #5 |
Cone Killer
Drives: 2012 SS Join Date: Dec 2013
Also in for lowering the stock seat height.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out! |
04-22-2017, 07:44 AM | #6 |
Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
04-22-2017, 05:32 PM | #7 |
Which 4 point harness are you using? #?
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro http://www.camaros.net/forums/showthread.php?t=182584 |
04-22-2017, 06:12 PM | #8 |
04-22-2017, 06:13 PM | #9 |
04-22-2017, 06:18 PM | #10 |
Here is some information: Nice thing is they are street legal. If you go this route with Brey Krause harness bar be sure you order "lap belts" with quick release clips on the ends for connection - they don't come that way, but can be ordered that way at no extra cost. Also here is a link from where I ordered - Subi sports does not discount, but are great to deal with and very knowledgeable!
Link: https://www.subesports.com/schroth/p...-asm/sch-20070 Schroth PROFI II - FE ASM SCH-20070 The Profi II-FE ASM is designed to be used as a four point system for street legal usage incorporating the required red push-button release design. For this reason it is perfect for use in Driver Education cars or any other application where stock seats are retained. A seat that was not originally desiged for use with a racing restraint should never be modified to accept an sub strap. The Profi II ASM incorporates Schroth's legendary ASM (Anti-SubMarining) technology that is the only thing like it on the market. ASM is an extra fold of material sewn into the inboard shoulder belt that elongates at a different rate than the outboard belt. This allows your upper torso to twist slightly. On the rebound phase, your torso is planted firmly back in the seat rather than allowed to slide under the lap belt. Features 3" polyester webbing at the shoulders and 2" polyester webbing at the lap belts, lightweight adjusters, and a push-button operated RFR rotary buckle. The 2" lap belt's notable feature is that it rides within the crest of the human pelvis where a 3" belt would rest on the edges. This allows you to get the belt up to an inch and a half tighter. That means the lap belt will be working earlier in the accident event because it gets loaded faster. It's also more comfortable and easier to adjust becuase there's less friction through the adjuster. The lap belt cofiguration is a pull-down adjustment with a sewn in bolt/in end. Dual or sigle substraps can be added to make it into a six or five point configuration. Shoulders come in 70" length. SFI 16.1, DOT, and FIA approved. Available in red, blue, black, and silver. |
04-27-2017, 04:45 PM | #11 |
Ordered a ZL1 Black Bow Tie to add to the updates to go on the back. Should be an improvement to the stock gold one!
04-27-2017, 05:18 PM | #12 |
Did you order that through your dealer? That looks great!
2015 Z/28
A/C and audio |
04-27-2017, 07:45 PM | #13 |
the moment you hit the track you will determine that the car is much better than your skill level unless you are a seasoned professional driver. Learn to use the momentum in the corners as our Z/28s can carry very high corner speeds. Braking is amazing and the moment you initially brake is most likely too soon and you can gradually shorten the braking zones. This is a big car that doesn't understeer so your line will be much different than other momentum cars. Sweep wide and get to the throttle quicker (not abruptly) than it seems possible. The Torsen diff allows powering out of the corners so no worries. I would recommend PTM 3 until you have many laps under your belt. It will allow lots of sloppy inputs and keep your car in check and out of danger while keeping your speeds high. Have fun and learn the car as it is quite a treat to drive a speeds that seem impossible.
05-26-2017, 10:07 AM | #14 | |
So I decided to live with it as is and live with it until I decide if I will install a track seat. |
