Old 05-13-2017, 07:11 AM   #1
Allanski
Drives: Car
1000 HP 2011 Camaro Convertible
1000 HP - 2011 Camaro SS RS Convertible $79,000 US, only 4000 miles
Not raced since built
ENGINE
- Performance Built Engine 427 CID Bored to 434 at 9.1 to 1 Compression
- GM LSX iron block new version #19260089
- Callies Dragonslayer 4.00” stroke Crankshaft
- JE Forged Pistons
- Carillo H Beam Connecting Rods
- Clevite Coated Main and Rod Bearings
- ARP Main Studs
- Cometic LSX head gaskets
- ARP Head Stud Kit
- Comp Cams Billet Camshaft
- Comp Cams short travel Lifters
- JPP Billet double row timing chain
- Melling High-Volume 50 psi Oil Pump
- Comp Cams Pushrods
- GM LSX DR cylinder heads #19166979
- PAC Titanium Retainers
- PAC Custom Springs
- PAC Titanium Bead Locks
- T&D 1.9:1 Roller Rockers
- GM LS7 aluminum intake manifold
- Edelbrock elbow
- GM 90mm throttle body
- Alcohol Injection meth kit
POWER ADDERS
- F2 Procharger
- Precision 46mm wastegate
- Procharger monster blowoff valve
- Custom fabricated stainless headers
- Turbonetics front mount intercooler customized for more air flow
- ID 2000 Fuel injectors
- Squash return HP Fuel System
TRANSMISSION
- Jake’s transmission 4L80 Stage 5 with transbrake
- Jake’s 3600 stall converter
- B&M magnum ratchet shifter
- Dynatech one piece aluminum driveshaft and safety loop
- G force 9" fabricated IRS rear end with 3.73 gears
Name:  1000 hp dyno chart.jpg
Name:  new hood image30.jpg
Also 150 shot of Nitrous not used while dyno testing
Toronto Ontario Canada
ph 905-633-8219
Allanski is offline   Reply With Quote
Old 05-15-2017, 10:56 PM   #2
Allanski
Drives: Car
Ummm
Really no questions?
So I guess you all figured it out that to build a car that runs 1000 HP
it really takes about 100K to get it right.
This is a great deal if you can get it!
Old 06-07-2017, 06:03 PM   #3
Allanski
Drives: Car
gone
