Old 12-23-2017, 05:34 AM   #1
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
160 thermostat
Have any used the 160 thermostat
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq dynojet.dyno btr stage3 cam, brain tooley racing dual springs kit, arp head studs and arp bolts,
Powered1le is offline   Reply With Quote
Old 12-23-2017, 07:47 AM   #2
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
Its very common for anyone that's done a cam/tune and other mods.
Not if it'll make much difference on a stock engine.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 12-26-2017, 08:40 PM   #3
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
You will need a tune to turn the fans on sooner to make it work. I had one on my 2011.
Pollock is offline   Reply With Quote
Old 12-27-2017, 10:58 AM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
i've got one, really helped keep temps down while staging and it should have a good impact on a road course. a little tip when refilling the coolant: take the upper radiator hose off of the radiator and fill the engine through the hose. i think mine has finally passed all of the air pockets.
as mentioned you will need to tune the fans to come on earlier
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 12-27-2017, 02:27 PM   #5
Powered1le
Powered1le's Avatar
Good to know information thanks
