12-11-2014, 10:47 AM | #1 |
Drives: 2013 2ss Join Date: May 2011
spraying a 100 wet shot untuned
ok i got a new to me 2013 ss (AUTO ) i just started building this car my previous camaro on my sig is gone(stolen almost 2 years already)....anyway my qustion is simple ..(can i spray a 100 shot on this engine safe..without a tune for now) i do know it is best to spray with a tune..but from previous experience i do know on my ls1 was not a prob .....please no insults...i just want other people insights and mabe one of u have already done this,,, thats why im asking....going to the track tonight and want to surprise my buddy with a stock auto also......already got the system installed and ready to fire
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
12-11-2014, 11:34 AM | #2 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Any way to pull timing? Colder plugs? Wideband to monitor afr? Do you know how to read plugs after doing a hit?
What kit is it and is the fuel system stock?
12-11-2014, 11:48 AM | #3 |
new tr6 spark plugs gaped at 32, zex black out syatem just like on my last camaro, and i got a window swicth installed already,yes i know how to read plugs..but i was just wondering if anyone else done this?
12-11-2014, 11:51 AM | #4 |
Shouldn't be an issue as long as you tune it in with jets to make sure it isn't lean.
Nick
Corvette Z06 -1200ish rwhp |
12-11-2014, 11:52 AM | #5 |
Drives: 416 w/TH400 Join Date: Mar 2012
if you can pull timing it shouldn't be a problem and read the plugs to make sure
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
12-11-2014, 01:17 PM | #6 | |
These new L99-LS3 are a lot closer to max timing so there is not the room you had on the LS1 If you put some race gas in, Say 5 Gallons of 100 to 10 Gallons of 93 that would cover you providing you have the AFR correct. Good Luck and go kick some butt. Ted.
www.jannettyracing.com
12-11-2014, 02:58 PM | #7 | ||
What is a good afr to shot for while spraying an ls3 on pump gas, I've heard everything from as rich as 11.5 and some say as high as 12.8??
12-11-2014, 03:03 PM | #8 |
I would stay in the 11.5 range.
12-11-2014, 03:08 PM | #9 |
Thank you, I come from a turbo 4 and 6 cylinder background and tuned for boost always stayed around 11.5 to 12:1 so figured it was similar with nitrous
12-11-2014, 03:14 PM | #10 |
Drives: All GM Performance Join Date: Jul 2011
12.1-12.5 should be ok, safer would be the lower. BR70F would be a better choice for a plug but the TR6 will do.
