Solo Performance
Old 08-06-2016, 06:39 PM   #1
Chantro5
Chantro5's Avatar
Drives: 2015 Dodge Challenger R/T Scat Pack
Overkill 80mm Throttle Body
Sorry, if this is in the wrong place or has already been said thousands of times, but I've used search and couldn't find anything. Just a couple of question on this. I recently purchased one, but I haven't gotten a shipped confirmation or anything all I know is that it is paid for.
1. How long will/would it take for it to ship?
2. How long will it take generally to arrive?
3. Will it work with a Vitesse Throttle Controller?
4. What kind of ballpark gains am I looking at with just the throttle body and also coupled with the VTC?
5. Would it void my warranty and is it hard and takes long to install?
Thanks to everyone who is willing to reply back and help me out.
“It is not that I'm so smart. But I stay with the questions much longer.”
― Albert Einstein
Chantro5 is offline   Reply With Quote
Old 08-06-2016, 07:09 PM   #2
Kenny Camaro
Kenny Camaro's Avatar
Drives: 2013 1LT RS Camaro
I got mine in ten to twelve days. Took 5-6 days to ship, 5-6 days to receive. It should work with the VTC, I haven't heard of it not working with one. VTC does not add hp or torque. It makes throttle response better. Depending on if you have any other mods, cold air intake,ect. you should expect 8rwhp from the 80. It isn't hard to install ,half hour to an hour. As far as the warrenty, it depends on the dealership and what the warrenty issue is. Technicly they can void your warrenty if they determine that is the cause of the failure. You can e-mail Will at Overkill and ask him about shipping, I did and he returned my e-mail the next day. The 80 increased my throttle response without a VTC, and the sound is deeper and more ballsy. It took about two weeks or so before the ecu 'learned' and adjusted to the larger throttle body. If you don't have all ready have one ,I would suggest that you get a cold air intake system , as this will work hand and hand with the larger TB and will also increase hp and give you more sound from under the hood. I love my 80, and I'm sure you will too. Have fun, enjoy, and ROCK ON!!
K.C.'s ported Overkill 80mm TB, K.C.'s ported intake manifold,Jacfab Extendolator manifold spacers,K+N Typhoon cai, Dynomax Valvetech axle back exhaust, Elite E-2 Catch Can, Jet stage two performance modual
Kenny Camaro is offline   Reply With Quote
Old 08-06-2016, 07:16 PM   #3
Flotek
Flotek's Avatar
Drives: 2015 RS camaro
This mod sounded great with all the hype it made over the last few months ,but the reality over time is I've yet to see much of any conclusive proof whatsoever that this is worth the time trouble or expense compared to a ported stock throttle body. A little better response and 2-3 hp isn't worth hundreds of dollars and piecing together a hodgepodge of questionable parts in my eyes ,unless someone has posted real world proof other than just a testimonial they think it helped out
Flotek is offline   Reply With Quote
Old 08-06-2016, 07:43 PM   #4
Kenny Camaro
Well the v-6 LFX doesn't get very much gains from any bolt on, especially after the first one is installed. So 2-3 rwhp is 2-3 more the the v-max gets. You could spend 500 dollars on high flow cats and not get very much more than the 2-3 that the 80 gives you over the vmax. People get high flows for the hp gain and the sound. The 80 has an improved sound while the vmax sounds no different than stock. Plus you don't have to send your stock TB in to get your core deposit back. You can sell it or keep it. V-max is 150 and the 80 is 299, so the difference is not 'hundreds'.
Old 08-06-2016, 07:53 PM   #5
dreyesforeal
dreyesforeal's Avatar
Drives: 2013 camaro LFX
Originally Posted by Sanjay Collins View Post
You have to remember though, both people on here that have dyno'd the 80mm against the VMAX without Will's tune didn't make anymore power.
Sanjay what's good . Yo you know if those two people had their manifolds ported when they compared ?
dreyesforeal is offline   Reply With Quote
Old 08-06-2016, 07:55 PM   #6
Kenny Camaro
The one and only lay over dyno chart that I've seen on the forum showed 2-3 gain. Granted , others like Camytt have not seen that gain, but the one that had the charted overlay did show it, and he didn't have the overkill tune.
Old 08-06-2016, 08:11 PM   #7
bleavens1962
Drives: 2014 1LS Camaro
I believe if you are FI, the 80MM would be a significant benefit
bleavens1962 is offline   Reply With Quote
Old 08-06-2016, 08:14 PM   #8
dreyesforeal
Camrytt did. He made 302 rwhp with both the VMAX and 80mm throttle bodies. It seems Will holds the key to its maximum gains.
Yeah adding two ported parts seems that a tune could support it. Maybe a tune is needed to take the full advantage like you said. Lol
Old 08-06-2016, 08:58 PM   #9
Kenny Camaro
I think the OP is installing his first two mods, the Vtc and the 80. So all these other comparisons had multiple mods, some had them all. So there probibly would be different results on from stock to the vmax or 80? What does the members think?
Old 08-06-2016, 08:59 PM   #10
Kenny Camaro
I think that would be true also.
Old 08-06-2016, 09:11 PM   #11
camrytt
camrytt's Avatar
Drives: 2014 L99
It actually came up at 299 hp with the 80mm, but the tuner said that was in the acceptable tolerance or something.
Things I noticed - it did sound better than the vmax. I can't recommend anyone getting it if they have a cold air inductions intake, it's a pain in the ass getting it set up with that for now. I hear they're working on fixes for it.
Also, if you don't have wills tune, idk if I can recommend it either. My tuner couldn't get it to stop making my car throwing the reduced power code on start up. After I cleared it it would work awesomely.
Current: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears.
Past: '12 LFX, full bolt ons + E85, 302hp/267tq
camrytt is offline   Reply With Quote
Old 08-06-2016, 09:17 PM   #12
dreyesforeal
Damn bruh I have the cai lol its cool tho . Might be one mod i juSt may pass. Hi flows over these
Old 08-06-2016, 09:20 PM   #13
camrytt
camrytt's Avatar
Drives: 2014 L99
Yea get the vmax one then it's good and stupid easy to install. Hfc will make your car a lot louder but that's about it
Old 08-06-2016, 09:49 PM   #14
Kenny Camaro
Found it post 455 on 80mm throttle body for LFX , will from overkill. Just bumped it up . 2-3 hp at 6500 rpm 80 over the vmax. Mjf12080 did the post
posts gone because you dont reply 2, z emails
