Old 08-19-2018, 01:14 AM   #1
jjterminella
jjterminella's Avatar
Drives: 2015 2ss/1le
Header install question
I will be installing headers soon and I was wondering how high the vehicle needs to be jacked up. Does anyone have photos of the vehicle in the air during the header install?
jjterminella is offline   Reply With Quote
Old 08-19-2018, 01:37 AM   #2
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
George-CZ is offline   Reply With Quote
Old 08-19-2018, 06:45 AM   #3
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Don't just get them barely off the ground. The more clearance you have the easier it will be to get your header in.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 08-19-2018, 07:25 AM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
As high as you can safely get it. Makes it easier. Also having a second set of hands helps. I drove mine partially up a trailer that I removed the center wooden boards from. Made it real easy.
More to come.
Black_SS10 is offline   Reply With Quote
Old 08-19-2018, 01:56 PM   #5
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
I had mine maxed out on jack stands which worked great. I did have to jack them up an extra few inches to get the OEM manifolds out but that was it.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 08-19-2018, 02:00 PM   #6
Synner
Drives: cars
Did it on $40 Walmart ramps. You're overthinking it.
Old 08-20-2018, 02:17 PM   #7
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Mine is lowered 1.25 inches and no way ramps would have worked. Getting the old manifolds out was where I needed the room but I didn't unbolt anything but where the cat attached to the exhaust. I put mine up quite a bit.
Sent from my SM-N950U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 08-20-2018, 11:47 PM   #8
mchaggis
mchaggis's Avatar
Drives: 2011 L99 2SS
I got sick of jacking the car up and lying on my back so I bought a 2 post car hoist. This it the best garage tool I have ever purchased. Also the most expensive but it is used all the time. Just wish I had one years ago.
Sorry, not really answering your question but just in case your under cars a lot, then do consider one.
mchaggis is offline   Reply With Quote
Old 08-21-2018, 10:56 AM   #9
NGUYP
Drives: Junk
As high and safely as you can especially on the driver side. My stock exhaust manifold kept getting caught up on the steer shaft, so I had to jack it up a little higher to get the right angle to pull it out.
NGUYP is offline   Reply With Quote
