Old 09-22-2019, 07:27 PM   #1
Keoni068
Keoni068's Avatar
Drives: 2015 Camaro 2LT RS
Want to go lower!
Hi guys!
I have a 2015 2LT V6 that currently has the GM GFX kit and BMR 1.25” lowering springs, and I would like to close up the fender/tire gap.
What set up would you recommend to go lower? How much lower can I realistically go as it’s my daily driver? Any recommendations are appreciated!
Keoni068 is offline   Reply With Quote
Old 09-22-2019, 10:14 PM   #2
Avenging Orange
Avenging Orange's Avatar
You are pretty much at the limit before you start affecting other suspension parts. Did you have bushings timed/clocked when the springs were installed?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-22-2019, 10:18 PM   #3
Keoni068
Keoni068's Avatar
Thanks! Yes, they were timed when I got aligned. If I go coilovers can I get over a 2” drop?
Old 09-23-2019, 12:45 PM   #4
KillboyPowerhead
Drives: 2015 Z/22
Coilovers will allow for a lower drop, 2" or more depending on the coilover, but as mentioned you'll start to negatively affect your steering and handling because you'll be straying too far from the original suspension geometry, inducing more bump steer, reducing wheel travel, limiting possible alignment specs (too much negative camber), etc.
Of course, there are ways around these factors such as a bump steer kit, adjustable suspension arms, coilovers with remote oil canisters, camber/caster plates, etc.
Overkill Tuned; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
