06-15-2021, 04:43 PM | #1 |
Drives: A Vette Join Date: Jan 2020
MT et ss vs Toyo r888r
Anyone had either of these tires on their Z? I know ones a drag tire and the other is more suited towards road course but both seem to have exceptional straight line grip from what I hear.
If you had experiences with either tire or even both which did you favor more as far as traction goes? How well does it put the power down when aggressive on the throttle from slow roll speeds and launching from the start? |
06-15-2021, 04:47 PM | #2 |
Drives: 2017 ZL1 Join Date: Apr 2020
The Mt I got wouldn't balance. The got the new nitto 555rII. I am very happy with them. I have them on rear full time
2017 ZL1 M6 Silver Ice Metallic
06-15-2021, 05:12 PM | #3 |
Drives: 66 Chevelle SS Join Date: Mar 2013
You might consider an ET Street R if you drag race. It is a DOT tire. My friend uses these on his Demon with success.
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
06-15-2021, 05:31 PM | #4 |
Drives: 2017 ZL1 Join Date: Jan 2017
Have the new Nitto 555RII on and couldn't be happier, drives like a street tire with the traction of a drag radial.
345/30R19 in the rear with PS4S 305/30/19 in the front
2017 Camaro ZL1 Coupe M6 (847whp Dynojet on 93)
06-15-2021, 06:34 PM | #5 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Have used both. Can attest to Street SS being a pain for balancing lol
Street SS will definitely grip better. R888R will grip almost as good once they have a little heat in them. R888R feel better though at high speeds 130+ and in turns, but the Street SS hasn't given me any concern at 170+. The R888R feel just a tad more planted in case you needed to make some sort of maneuver. From a dig I prefer the Street SS. Daily driving I also prefer them because they make a LOT less noise. The noise in the R888R didn't bother me per se, but it certainly is nice not having to hear them all the goddamn time. My Street SS also have lasted me a lot longer than the R888R. I think at 5-6k the R888R were about done on the rears. The Street SS are at 6k and seem like they have a lot left in them. I would like to mention I don't baby my car either. The miles on my tires are from aggressive driving and racing. My next tire will probably be a Street R because I'll be pushing more than I am now. I've heard a lot of good things about that new Nitto tire so I would research into that. For a stock car though I think the R888R work just fine. I was getting 3.4 0-60s everytime with them. If you're pushing more than stock though I'd say go for the Street SS. |
06-15-2021, 08:13 PM | #6 |
Excellent review man really appreciate the detailed write up. Glad to hear you had experiences with both tires this was very helpful.
06-15-2021, 08:19 PM | #7 |
06-15-2021, 08:48 PM | #8 |
Drives: '20 ZLE Join Date: Jun 2020
MTETSR radial and Forgestar F14 wheels mounted today
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
06-15-2021, 09:46 PM | #9 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
I have the R888s and I’m extremely pleased. (I’ve had them about a month now.) I can’t believe how well they hook up. They put the power to the ground and the car handles better than the OEM tires. Zero complaints with them.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
06-15-2021, 10:55 PM | #10 | ||
Drives: High HP V8 Join Date: Apr 2020
I have the new Nitto 555r2 tires on my Hellcat and I’m not really pleased with them. They let me down at the drag strip and doing 40 mph roll races at the track they slip on me. I’ve heard great reviews about them so I thought I’d give them a try. Only positive thing about them is they ride just fine in the wet and handle corners decently but other than that traction wise not to thrilled about them since they don’t seem to work for me. Only able to hook around 50 mph with them and no lower. Mind you this is on a stock Hellcat too so I am somewhat disappointed with them to the point where I feel like there 555 g2s instead of 555R2s. Definitely gunna look into the MT et street ss next. I’ve heard there was some sway at high speeds and that they have no speed rating but since you said you’ve took them up all the way up to 170mph plus with no concern then I guess it might not be an issue. With the MT’s were you getting the same 0-60 times as you were with the r888rs or better? What psi were you running the MT’s on the street and strip? Quote:
That’s good they hook up well especially on your 707 whp ss 1LE there man. What’s the lowest roll speed you can hit the throttle hard with them hooking and not losing traction on you? |
06-16-2021, 12:32 AM | #11 | |
Used to own a ZL1
First note the sway. I DID have sway above 110. It was honestly really bad and scary. I don't know if it there was some break in period, but I had constantly needed to take my tires to get rebalanced because they were so grippy they were spinning on the rim. I ended up gluing them with hi tac on the rim. Anyway at around 1k miles the sway was gone, and was noticeably less when I lowered the PSI to around 22-24. As time went on I stopped airing them until they got down to 16 psi or so then aired them up to 28. The tires don't sway at all anymore. Trust me I would not be going to 170+ if they were swaying. I'm not sure why they swayed at the start. Maybe because I had them sit so long before mounting them, maybe because the balance wasn't good, or maybe they just needed a break in period. I can say though the last 5k miles they've been nothing but perfect as a daily driver (except rain good god). I haven't been able to compare the 0-60s because my vette did not come with a timer, but I can say with certainty they hook better than R888Rs. Everyone I know who runs Street SS runs them at 28 psi on the street. Then below 20 on the strip. The R888R when a little warm would hook for me even at a 30 roll. Like dead hook. The Street SS could do it at 10 mph. The Street SS last a looot longer than the R888R. |
06-16-2021, 07:52 AM | #12 | |
Petro-sexual
It's really only at WOT, so I just wonder if it's a function of the tire getting-up on the sidewall and just making the tread "rounder". I'm probably about 700 to the tires and wonder if the more power you try to put to these, at higher air pressures, the more pronounced the sway is. I know I'm on cheap wheels, and they aren't beadlocks, but even on the street I get tire slip on the wheels. I've probably put somewhere around 15-20 digs on an unprepared asphalt surface and have gotten a lot of wheel-to-tire-slip. I'm already about 180* slip on the driver's side. Fortunately - balance doesn't seem to be bad yet, but I'll be tacking them, too. They hook pretty good. I am seeing wheel slip from as much as the 3-4 shift (around 80) and they'll spin through a roll from second. That's an improvement over the GYs but it's hard to get over that sway...
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
06-16-2021, 09:06 AM | #13 | |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Mickey Thompsons are not that great for the street. Have had them on different cars over the years. They balance like shit and only hook good for the first 500 miles or so. once the tread is balled up then they lose a lot of traction on the street. At the track they are great. It's too bad Hoosier DR2 doesn't offer more size options because I would take them over a MT any day. Toyo R888 are solid but noisy.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
06-16-2021, 10:21 AM | #14 |
KingLT1 I'm surprised you are running the 35's. You are losing some gearing. The pos mt ss I had were 35's. Personally I don't like the taller tire
