Old 02-15-2019, 08:37 AM   #1
csorrentini
csorrentini's Avatar
Drives: 2010 Orange 2SS/RS
West Palm Beach, need some valve work.....
Hello all,
I am having a misfire in cylinder 7 and a clicking noise as of yesterday. Dealership said all the tests they did checked out other than the compression test. They stated it was good compression but bad running compression. Believe a valve or valve guide is the problem. They are trying to charge me $1800 to get in and replace all gaskets and assuming valves but they weren't even on the quote so not even sure about that. Any mechanics local that can help a semi mechanically inclined guy out and get this baby purring again?
csorrentini is offline   Reply With Quote
Old 02-15-2019, 09:03 AM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
LS3, L99, LSA or LS7?
Sent from my SM-G965U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-15-2019, 09:13 AM   #3
csorrentini
LS3
Old 02-15-2019, 09:18 AM   #4
sixty9fordkiller
Are you mechanically capable of replacing the heads yourself?
Bone Stock
Old 02-15-2019, 09:22 AM   #5
csorrentini
Never done it before, I am sure I could if I put the time into it. but generally like to have experienced people do it or be around to learn the initial time.
Old 02-15-2019, 09:36 AM   #6
sixty9fordkiller
Ahh....ok. Well, i would explore all your options if the heads are gonna come off. gwatney performance has ported LS3 heads for about $1150, fyi
Bone Stock
Old 02-15-2019, 09:49 AM   #7
csorrentini
So I was in the process of deciding if I wanted to sell this car right before this happened and purchase a 6th gen already SC'd and such from Camaro6.........but then of course this happened. So I am not sure how much I want to actually do to it atm.
Old 02-15-2019, 10:09 AM   #8
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
Now we are a distance from you but we do some great work on heads that you can send us and we can send back. You can send us your head with valves bare and clean and we will do a valve job with upgraded springs and necessary hardware like locks and retainers for 999.99$ plus shipping back to you. Also that would be a perfect time to install a bigger cam for that old school sound. Plus doing both usually picks up 80-100hp to the ground. My name is Jake message me or call me if interested 313-561-5500
https://www.livernoismotorsports.com/product/LPP761100
Livernois Motorsports is offline   Reply With Quote
Old 02-27-2019, 02:59 PM   #9
csorrentini
I decided to remove them myself and get my learn on. Can this all be done with the front end left completely untouched or do I need to take anything apart in the front end of the car to access everything easy?
Old 03-02-2019, 03:49 PM   #10
bill522
Drives: 2014 LS Camaro
Redline Motorsports in Pompano might be able to help you...
bill522 is offline   Reply With Quote
