12-06-2011, 11:23 AM | #1 |
F(r)iend
Drives: '08 G8GT PBM Join Date: Jul 2011
Clutch sticks when cold?
Here in CT the mornings are getting down into the low 30's, sometimes high 20's... a few times now I've noticed my clutch pedal sticking as I go to start the car. I do not start it, but instead press the pedal in and out maybe 6 - 7 times until it is smooth again, then start. After that she's fine.
Is this something I should be worried about?
2008 G8GT Panther Black Metallic
Custom 4" Intake, AEM DryFlow Filter Custom HSRK, Custom "solo" Axle-back MonteSS DiabloSport 93 Octane Tune Red Painted Calipers, Ceramic Pads Cross drilled / slotted rotors, 20% tint |
12-06-2011, 11:30 AM | #2 |
Drives: 2011 Black Camaro 2SS/RS Coupe Join Date: Jul 2011
Only if your car is an automatic.
"Being persistant and never giving up may not always get the job done, but it just may annoy someone else enough to make it worth your while." |
12-06-2011, 11:34 AM | #3 |
F(r)iend
I've never a V8 before, but on my 4's and 6's this has never happened, even at "below zero" temps...
12-06-2011, 11:35 AM | #4 |
LS3 Black Widow
Drives: 2012 45th 2SS LS3 and 1968 Mustang Join Date: Nov 2011
Probably just a little frozen up from the cold.
12-06-2011, 01:06 PM | #5 |
Cold days getting in 2nd gear sticks on my M6. Dealer wont fix it.
12-06-2011, 01:11 PM | #6 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
The clutch is known to have a few issues with sticking. There is an aftermarket kit that adds a spring to the clutch to make sure it returns fast. If you are having issues I would suggest looking into it. I wouldn't think it could cost much...
12-06-2011, 01:27 PM | #7 |
El Hefe
Drives: Black Camaro 2SS/RS Join Date: Jul 2010
I had the same problem recently, the dealership looked at it and told me everything was a ok. It has not happened since the visit, but who knows just monitor it I guess.
12-06-2011, 03:08 PM | #8 |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
Same here, grinds into 2nd on first shift when car is at or below 30 degrees. Solution: skip the first shift and go 1-3 instead. :-)
12-06-2011, 08:21 PM | #9 |
Drives: Inferno Orange 2013 SS/RS LS3 6M Join Date: Oct 2011
Haven't this problem in mine and it was 10 degrees here today...
With this in the garage, I smile every day 6/29/2012 New 2013 ordered... 8/21/2012 New 2013 picked up!!! |
12-07-2011, 07:41 AM | #10 |
F(r)iend
It was 55* this morning, and it was still stuck for 5 - 6 pumps
12-12-2011, 04:17 PM | #11 |
Drives: 2011 Camaro LT Join Date: Dec 2011
first factory manual trans is junk and should be rebuilt by someone who knows what they are doing second there is a problem with the clutch return have it fixed asap
12-13-2011, 03:11 PM | #12 |
Drives: 2011 Camaro 2LT - MT6 Join Date: Oct 2011
I have that problem with 2011 V6. A couple of attempts have been made by service department to correct it. You have to pull the pedal up with your toe to get it back to the top unless you press it a couple of times. After that, it is OK the rest of the day. The V8 has a spring available at www.lingenfelter.comand a discussion of the issue for V8 clutches.
12-14-2011, 11:53 AM | #13 | |
F(r)iend
12-14-2011, 01:43 PM | #14 | |
Similar Threads | ||||
Sticking clutch pedal issues - Tick Performance feels your pain! | Matt@Tick | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 185 | 12-22-2018 12:21 PM |
Fastlane Pipeline Cold Air Intake at Phastek Performance | Jason@Phastek | V8 Bolt-Ons & Tunes | 2 | 03-30-2016 07:19 AM |
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! | AutoAgenda | V8 Bolt-Ons & Tunes | 438 | 11-23-2013 10:49 PM |
\\\\\\K&N INTAKES BLOW OUT SALE +FREE SHIPPING////// | GmPartsDirect.com | V8 Bolt-Ons & Tunes | 2 | 03-29-2011 04:27 PM |
Group Buy - ADM Performance Cold Air Intakes @ Apex Motorsports | Apex Paul | V8 Bolt-Ons & Tunes | 34 | 06-08-2010 08:09 PM |
