Old 11-27-2017, 05:44 PM   #1
BRN2SPD
Drives: 2012 2SS 45th Anniversary Edition
112 lsa vs 114 lsa
I'm looking to do a TSP 235/239 cam but want to know what the pros and cons are of going with 112 lsa vs going with 114 lsa. It is my daily car so drivability needs to be taken into consideration but I also want power, chop, etc. Any advice is worthwhile!
2012 45th Anniversary 2SS Convertible
-Borla Atak
-Stainless Works LT off-road headers
-K&N Intake
-Resonator Delete
-Stance SF03 Titanium Wheels
2002 35th Anniversary SS Convertible
-SLP Performance Package
1991 Z28 Convertible
-Cam
-Heads
-Custom 350 Engine Build
BRN2SPD is offline   Reply With Quote
Old 11-27-2017, 05:51 PM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
The 112 will idle worse but make more midrange torque.
zz430camaro is offline   Reply With Quote
Old 11-27-2017, 06:02 PM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
http://www.compcams.com/Pages/413/ca...ion-angle.aspx of course it will have chop and it will be with a wider power band slightly and not affected too much for top HP numbers our stock cam comes with mega LSA ......its good for not making any PTV or other issues also etc benefits from the wider LSA and more power under the curve so to speak with more wider power band a little, then some places also add timing in a grind also, like mine now is 114+4 but drives just like the 112 I used to have the 235/239 good cam from TSP. Maybe its better on the brakes with the wider lsa also? theres things to be said for both ...
Old 11-27-2017, 06:03 PM   #4
BRN2SPD
What does idle worse mean? Idle rougher? Buck more at low rpm? I can't seem to find anyone running 235/239 with anything but 111 or 112
-Borla Atak
-K&N Intake
-Resonator Delete
-Cam
-Heads
Old 11-27-2017, 06:08 PM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
lotta duration for a DD...IMHO...
Old 11-27-2017, 06:15 PM   #6
zz430camaro
Drives: 2015 1LE
Idle will be more choppy and it will buck more. Running the 114 will improve the idle but will kill more torque that is already low with the big cam that is why no one does it. Its a high rpm cam, that simple.
Old 11-27-2017, 06:18 PM   #7
zz430camaro
Drives: 2015 1LE
I agree, I would go with a smaller cam for a daily driven car.
Old 11-27-2017, 06:40 PM   #8
Bo White
Bo White's Avatar
Driveability will be better with 114
Power will be better with 112
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-27-2017, 06:53 PM   #9
BRN2SPD
Is a 114 still going to chop at idle or will it not be noticeable?
-Borla Atak
-K&N Intake
-Resonator Delete
-Cam
-Heads
Old 11-27-2017, 07:13 PM   #10
zz430camaro
Drives: 2015 1LE
YES it will have lots of chop.
Old 11-27-2017, 07:34 PM   #11
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
I have the tsp 235 239 627/624 on a 111lsa my car idles at 850 rpm has a lot of chop with my 2 inch headers no cats. Too me the top end is insane for this cam which is what I wanted my redline set to 7k I shift at 6800
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 11-27-2017, 07:58 PM   #12
deddmoneydave
Drives: 5th gen
At 235/239 that's 13 degrees of overlap on a 112, 9 on a 114, it's gonna chop hard with either cam and neither will have particularly great driveability to be honest. Might as well go with the 112 imo
deddmoneydave is offline   Reply With Quote
Old 11-27-2017, 08:09 PM   #13
BRN2SPD
Thank you for your input! I was told the 114 will tune easier and have less annoyances such as bucking
-Borla Atak
-K&N Intake
-Resonator Delete
-Cam
-Heads
Old 11-27-2017, 08:30 PM   #14
deddmoneydave
Drives: 5th gen
Comparatively less than on a 112, yes. But it will still be a little rowdy at low rpms
