Old 12-28-2017, 03:09 PM   #1
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
DTC P013E and P014A
Just received an unwanted xmas gift. I received codes P013E and P014A a few weeks ago, cleaned my CAI filter and the problem went away till yesterday.
P013E HO2S Delayed Response Rich to Lean Bank 1 Sensor 2
P014A HO2S Delayed Response Rich to Lean Bank 2 Sensor 2
From what I've read, I plan on trying the spark plugs, wires first. I'm wondering if it's the gas I used last, was in a pinch and filled up at Circle K (have always filled up at Shell 91 octane). I've made no changes to my Camaro for some time.
I've always had some back fire after installing the SC several years ago, maybe could be an issue now? I've also noticed that my Camaro stalls off the line briefly, I press the gas pedal (not a lot) and she moves then there's a short stall that moves me forward until it resumes accelerating. I'll have to run these by my tuner.
Anyone have recommendations for the spark plugs, stock or aftermarket due to my SC install? Anyone try NGK IRIDIUM IX SPARK PLUG TR5IX?
Thanks,
Gary
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 01-06-2018, 06:49 PM   #2
WHT13SS
Drives: 2013 RS2SS M6
I have the same problem after stage 3 cam and tune. It back fires when I’m on a incline trying to take off and Boggs off the line for a brief second. I’ve taking it back to the turner 4 times and no one can figure it out. I’m now having problems with doing burn outs with traction control off, it Boggs down like it wants to stall. They said I have to rev over 4000rpm and pop the clutch which doesn’t make since. Does anyone else have this problem?
WHT13SS is offline   Reply With Quote
Old 01-06-2018, 06:51 PM   #3
WHT13SS
I have a 2013 2ss m6 471rwh
Old 01-06-2018, 07:55 PM   #4
Missile Man
Finally installed Summit Racing wires and NGK plugs, big difference, engine purrs like a kitten now, acceleration is smooth and steady now. The stock plugs had a lot of ware on the electrodes, had to drain the radiator to get to the driver side front 2 plugs. The engine check light actually went off when I added octane booster and fuel system cleaner prior to changing the plugs but the plugs needed to be replaced.
I'll have to wait till the next time I do a cold start to see if the backfire occurs. I didn't realize how rough the Camaro was running until I replaced the wires and plugs. The stock plugs didn't come close to making it to 65K miles, I assume due to the SC, plugs were in bad shape.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 01-06-2018, 08:00 PM   #5
Missile Man
Ya, something sounds fishy. You shouldn't have to rev to 4k, that's nonsense. Did you modify your fuel system or install bigger fuel injectors? Maybe find a different tuner?
2010 Black 2SS L99
Mods:
* CAI Intake
Old 01-07-2018, 11:17 AM   #6
WHT13SS
I think I’m going to take it to a different tuner, I really feel like the traction control kicks on even after it is clearly disable.
Old 01-16-2018, 09:35 AM   #7
Missile Man
FYI
Looks like the spark plugs (wires) fixed the P-Codes, no check engine light after replacing them.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 02-11-2018, 08:57 AM   #8
Missile Man
The P014A retuned, oxygen sensor bank 2 sensor 2.
Can someone verify that the bank 2 sensor 2 OS is on the driver side, aft sensor.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 02-14-2018, 03:12 PM   #9
Missile Man
Anyone???
2010 Black 2SS L99
Mods:
* CAI Intake
Old 02-14-2018, 03:45 PM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
Anyone???
Could be in the tuning or warn sensors.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-14-2018, 03:52 PM   #11
Missile Man
Ted.
I've had the tune for several years, the P-code is fairly recent and intermittent. I figure the O2 sensor is fairly cheep to purchase. Just going down the list for this P-code. It's got plenty of hp/acceleration.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 02-19-2018, 11:27 AM   #12
hillshooter
Drives: 2015 Camaro SS commemorative
What heat range NGK did you go to? you mentioned 5 earlier and thats opposite of what you want. I would say a 7 is the most common plug on a boosted LS. Also really important to gap them at .028. Also I wouldn't get to fancy on plugs. the NGK BR7EF is what I have had the best luck with.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 02-20-2018, 06:22 AM   #13
Missile Man
I went with the NGK IZTR5B11/1465. It's been a while, what's the down side to running the hotter plug? Gap factory set to .040, why do you recommend the smaller gap size? I imaging I'll be replacing the plugs sooner due to the hotter plug.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 02-20-2018, 07:22 AM   #14
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
You reduce the gap so there is less of a chance that the boost will blow out the candles/spark
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
