04-25-2022, 04:49 PM | #1 |
Drives: 2010 2SS/Black Join Date: Mar 2009
A/C Issue
Hello,
I read through the existing A/C post but my issue seams to be a little different. The A/C clutch didn't engage so I swapped the A/C fuse and relay, didn't help. I checked the A/C fill port and it was well into the green. I depressed the valve on the charge port and only air came out. I released the air just to the lower red line of the recharge can and recharged the system. The A/C clutch engaged and it blew cold air. A couple of days later I drove the car and it blew hot air again. I don't see any apparent leaks anywhere. I've yet to go back and check everything again. I'm not real knowledgeable with A/C, if there is a leak how is the system maintaining pressure? Just looking to see if anyone has experienced this?
2010 Black 2SS L99
Mods: * CAI Intake * Magnuson MP2300 TVS Supercharger/RDS Spacer * Vector Motorsports Tune * Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series * R1 Concepts ceramic pads and slotted/drilled rotors Last edited by Missile Man; 04-25-2022 at 05:04 PM. |
04-25-2022, 06:33 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Probably has a leak but diagnosing ac vie the web isn’t really possible and you will need some pretty expensive tools to fix it right. Better of to take it to a professional.
04-25-2022, 09:30 PM | #3 |
Drives: Never just fly under the radar Join Date: Jul 2015
expansion valve
Old Skool |
