Old 09-26-2023, 09:41 AM   #1
Apharaoh06
Drives: 2010 Camaro SS
z/28 Control Arms
I am looking at upgrading my front rearward lower control arms to z/28 spec. The part numbers 23105014 and 23105015 are for the z/28 14-15 year model. Is there any verified difference in bushings, etc. compared to the stock SS reward lower control arms. My radius arms are z/28 spec.
Apharaoh06 is offline   Reply With Quote
Old 09-26-2023, 12:31 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Same arm, different bushing. According to JusticePete the non Z/28 bushings are very well made. If you need to replace the arm you might as well go Z/28, otherwise, unless you race there is probably no reason to upgrade.
KillboyPowerhead is offline   Reply With Quote
Old 09-26-2023, 02:01 PM   #3
gtstorey
It looks like the Z28 arms are stupid cheap right now and the SS ones are stupid expensive, at least on a couple of the sites I checked.
