Old 10-22-2023, 10:19 AM   #1
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Titanium open ended lug nuts
Anyone run these or similar lug nuts? 2lbs total savings for all four corners isn’t too bad considering that is unsprung weight and I believe for every 1lb lost of unsprung weight it equals to 4 or 8 lbs of sprung weight. These also have a brake cooling effect I guess from the open ended design which lets air get to the brakes.
427 Dart block, M311 Heads, Pat G Custom Cam, ATI Balancer, BO White Stage 3 TB, Custom CAI, FI Tech Sheet Metal Manifold
_Onyx_Wolf_ is offline   Reply With Quote
Old 10-22-2023, 12:43 PM   #2
bsn
Drives: 2013 ZL1
Yes there will be a slight decrease in unsprung weight but it will never make a difference that you would ever notice even if you were running carbon fiber wheels and carbon ceramic brakes. The claim of increased brake cooling is bogus plain and simple, galling will almost certainly be a problem.
bsn is offline   Reply With Quote
Old 10-22-2023, 03:33 PM   #3
_Onyx_Wolf_
Thank u for the input
