Old 06-18-2018, 11:39 PM   #1
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Found this during my header install..
2014 LS3 at 38000 miles. Installing long tubes so I took the plugs out. Spark plug on the left is #2 cylinder. Right side is #1. All looked good except #2
What is the consensus on this?
Sent from my SM-N950U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 06-19-2018, 12:00 AM   #2
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Replace them gap is gone
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 06-19-2018, 07:25 AM   #3
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Yes I agree. Just never seen one of these destroyed in 38k miles
2014 2SS/RS LS3/M6
Old 06-19-2018, 07:43 AM   #4
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
Just replace them. I don't think it's anything to lose sleep over.
ZEN357 is offline   Reply With Quote
Old 06-19-2018, 07:57 AM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I would recheck the new plug after about 2000-3000 miles. It is unusual, but not unheard of.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-19-2018, 08:57 AM   #6
Pro-tuned
Pro-tuned's Avatar
If you change them recheck as mentioned above and if it’s burned down again look for lean out in that cylinder (clogged injector).
Old 06-19-2018, 11:50 AM   #7
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
No Worries , replace them with NGK V copper plugs and check them every 10000 miles .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 06-20-2018, 07:55 AM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Best thing about NGK is for $22 you swap them every 3rd oil change and roll on lol
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 06-20-2018, 12:14 PM   #9
lazerlemonta
Drives: 2010 C6 1LT
Mine looked just as bad at 38k in my C6.
Best MPH 134.82
Old 06-20-2018, 03:21 PM   #10
DaddySS
Kept The Faith
DaddySS's Avatar
Drives: 2011 Camaro SS Convertible
Strange. Looks marginally hotter. Is it tuned? What octane fuel?
2011 Vert - 2SS/RS 6spd Triple Black
DaddySS is offline   Reply With Quote
Old 06-22-2018, 05:45 PM   #11
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
It has only been tuned for 3k miles. It's tuned for 92
2014 2SS/RS LS3/M6
