08-17-2023, 03:18 PM | #1 |
Drives: 2017 Camaro 1SS Convertible Join Date: Apr 2023
Goal: 700 HP and 700 lb•ft torque
TL/DR:
I’m trying to mod my SS to make power just north of a stock ZL1, somewhere around 700 HP and 700 lb•ft torque. Mainly a street driven vehicle, with occasional track days. What combination of mods would get me there? *** Since buying my A8 1SS last September, I’ve stuck with a NA approach for my car, with the following mods installed:
However, as I read more and more, I’m starting to strongly consider going with a forced induction setup. Choosing a blower isn’t easy, but it seems like a ProCharger would offer a good balance of affordability, compatibility, power, and ease of installation. To sum up what I’m considering changing: + Port throttle body + Port intake manifold + Port cylinder heads + Swap camshaft + High flow fuel injectors/pump + Add ProCharger + Add Water-Meth (because I only have sporadic access to E85) + Swap exhaust for Borla S-type axle back + Get a decent tune Is this setup reasonable for my goals, or would you add/remove any modifications? Would you pick a different supercharger? Is all the porting a waste of time and money if I’m going forced induction anyways? Do I need to worry about upgrading any engine internals or drivetrain components at these power levels? Thanks! |
08-17-2023, 03:48 PM | #2 |
Drives: 2016 Camaro SS Join Date: Oct 2021
make it simple.
Blower of choice. Add toohighpsi port injection system. good flex tune. Will get you there.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
08-17-2023, 04:14 PM | #3 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I dont have any experience adding a blower to an existing N/A car but you have found the right place to ask... I would just like to throw out the idea of purchasing a used LT4 set-up... Plenty of build threads on here of folks who have... and there is a seemingly never ending supply of LT4 take off; blowers, TB's, Injectors (im selling a set now), HPFP, and low side pumps... for what i would imagine to be 40-50% the cost of a procharger system, with alot more low end torque... food for thought.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
08-17-2023, 04:31 PM | #4 |
Drives: Chevy Camaro Join Date: Sep 2022
All the porting is not the best place to spend that money if you're adding boost. What are you trying to do? Competitively drag race on a track, roll race or just want more power for driving around? The procharger will need a looser converter to launch very hard at the track. If you're doing cam and considering spending the port money, the bottom end of the engine isnt that much further to put a forged piston/rod setup in. Cheapest easiest setup to throw on and go pretty fast would be something like laynlo15's setup, pd blower, port injection, drag pack and run 9's all on the stock engine.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
08-17-2023, 06:44 PM | #5 |
Thanks for all the feedback! Looking at some of your suggestions, it sounds like a lot of those mods may be overkill; going with a simpler approach with a blower, a port injection system, and a solid tune for 93 and E85 will take me just about as far as I would need to go.
08-17-2023, 07:53 PM | #6 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Maggie 2650, ToohighPsi, Rotofab and E65 all on the stock fuel system. Stop blowing money on stuff that you don't need. You can make over 700 and 670 torque easily, I made it on an Lt1 fuel system with just a JMS voltage booster and a 2300 Maggie and of course Toohighpsi port injection. Geezzz its just so simple, no heads, no headers, no cam, just a 103 snout and 95mm TB. Send me the difference I just saved you on all that stuff you don't need. Sorry for ranting just trying to save you real money.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
08-18-2023, 12:09 AM | #7 |
Lol yeah, it sounds like a lot of the stuff I was originally going to do (like heads/cam, porting, etc) would be a waste of money, time and effort. It’s a lot simpler than I thought. I definitely tend to overthink things, lol
08-18-2023, 07:20 AM | #8 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
If you have any procharger questions feel free to ask me. I have installed everything myself (including port injection) and "sort of" did the tuning myself with massive amounts of help from the forum and a base starter tune.
I feel like my setup is doing very well now for a stock bottom end LT1. Have not had a chance to run at the track after pulley and PI though. Shooting for a low-mid 10 run.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
08-21-2023, 09:50 PM | #9 | |
Drives: SS 6 speed of course Join Date: Jan 2016
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
08-22-2023, 07:18 AM | #10 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Flex Fuel kit with no tune is useless unless you tune it in.
Where in FL are you? Just moved down from VA
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods Last edited by adamjwilson; 08-22-2023 at 08:35 AM. |
08-22-2023, 07:54 AM | #11 | |
With the 3.7 pulley at 6400 shift peak boost is 11.5-12 psi. Average 9-10. But for the tall 4-5 shift, i still hold it out to 6700 and peak is around 13.75 psi. I have all stock engine and exhaust components except for whats in my sig, so boost will be higher compared to someone with LTs and no cats.
08-23-2023, 07:12 AM | #12 |
Yeah, I have all the hardware installed but haven’t gotten the tune yet, so I’m still stuck running 93. I’m in Gainesville! Closest station with E seems to be in Ocala.
08-23-2023, 07:22 AM | #13 |
I just move to South Gulf Shores and I have a E station about 12 miles away thank goodness. The thought of buying 55 gallon drums of E85 was not pleasant!
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
Tags |
help me, meth, porting, procharger, upgrade |
