07-21-2018, 08:10 AM | #1 |
Drives: 13 ss Join Date: Oct 2017
2011 struts on a 2013 Camaro ss
I have a 2013 camaro found a set of low mile struts from a 2011 will they work?
07-21-2018, 01:23 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Upper End link hole my be larger on the 13 vs the 11.
Orange Krush II
07-21-2018, 08:05 PM | #3 |
USA-1
That's a downgrade man...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
08-07-2018, 08:56 AM | #4 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Chevy did improve the damping on the 2012 SS (FE3) struts. But many of the 2011 SS's that were later in the year builds got them as well.
Check the part numbers on your current struts and compare them to the ones you're looking at. They could be the same. |
