06-26-2011, 01:13 PM | #1 |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
Snake Oil?
Thoughts? Experiences? http://www.evanscooling.com/coolants/
06-26-2011, 07:21 PM | #2 | |
Ted.
www.jannettyracing.com
06-26-2011, 07:34 PM | #3 |
Drives: 1999 Trans Am Join Date: Jul 2009
It does work by pulling more heat out of the motor but I see the benefit more towards hot motor's like road racing. We tried it on a high hp car and the added heat of the 220 running temp hurt power by detinating under boost.
So,it works very well but is for a certain market. |
06-26-2011, 07:35 PM | #4 |
knows 2 facts about ducks
Seriously? I mean I'm not doubting you Ted, just comes as a shock to me. The claims they made were pretty far fetched to me.
06-27-2011, 08:30 AM | #5 | |
Many street rods use it, Many Road Race teams, Many Circle track teams, and Everyone who uses it Swears by it. Evans is Responsible for GMs switch to Reverse Flow Cooling back in 93 on the LT1, So this Guy knows a little about Cooling systems. Ted.
06-29-2011, 12:34 PM | #6 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
we use this on ALL of our big builds. It works VERY well and we have had to run under some extreme conditions where the engine water temp was well above 240 for extended periods of time. Just check track rules, some places hate the stuff and won't allow it because it is some seriously slippery stuff that takes hours to remove from asphalt!
I know Evans can explain it better but to try to lay this out simply; because the boiling point is so much higher, those little air bubbles that appear at the bottom of a pan on a stove as the water heats up are the same air bubbles that turn into pockets that build up on the sides of the cylinder walls. As those areas bond to the walls, that creates a hot spot on the cylinder wall creating even more heat because there is no way to transfer the heat out anymore on that area. So that in turn increases the size and amount of those air pockets creating a boil over situation. By utilizing a fluid that will not create those small bubbles, the cylinder walls keep a more uniform temperature and the temperatures increase slower over time. Without all those air bubbles forming larger air pockets, the fluid does not get pushed out or bubble over as does normal aqueous coolants once those air pockets get large enough to seperate from the block. And since this fluid has such a high boiling point, there is no need to run high pressure radiator caps. Evens recommends a 6psi cap. Simply put... Awesome stuff! |
07-02-2011, 07:17 AM | #7 | |
12-15-2012, 07:15 AM | #8 |
Are there any disadvantages for a daily-driven non-race car other than the one-off cost?
What - if anything - needs changing on the cooling system to make efficient use of this coolant?
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73) CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials |
12-15-2012, 08:08 AM | #9 | |
Each person should consult with Evans for they're application.
Similar Threads | ||||
GAS PRICES GOING UP 5 CENTS IN GTA APRIL 2ND, 2011 | SQUALO | Canada | 56 | 04-21-2011 03:19 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
