12-25-2013, 06:57 AM | #1 |
Burnn1
Drives: 2011 2LT Join Date: Nov 2010
2011 V6 Burns Oil
72,000 highway miles on my 2011 V6. This summer, she started burning oil at about a quart every 3-4 tanks of gas - almost as bad as my Vega did way back when. Garage floor is clean - unlikely it's a leak. Dealer says "it happens on older cars - Chevy recommends checking oil every time you gas up". I think this is BS and should dump her. Auto Zone says use Lucas Stabilizer.
Thoughts? |
12-25-2013, 08:21 AM | #2 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
Probably a stretched timing chain. I know the LLTs have issues with burning oil and stretched chains.
12-25-2013, 09:44 AM | #3 |
Let's go Rangers!
This. Common issue on the LLT, do a search and you'll come across many threads.
12-25-2013, 10:35 AM | #4 | |
having FUN now 13.66@101
2 separate issues. Best thing you can do is change the oil often, every 3k - 5k miles, do not follow the DIC. If you read some of the GM information they report that burning 1qt. / 1000 miles is normal. I am at 59K miles and just now seeing I am losing about 1/2 qt. per oil change. Also depends on how far you drive per start up. The more you can get the oil to operating temperature to burn of moisture the better it is for everything.
12-25-2013, 10:53 AM | #5 | |
Drives: 1971 Monte Carlo/2010 Camaro 2LT Join Date: Sep 2007
2024 Camaro SS convertible
2010 Camaro 2LT 2019 Cadillac CTS 1971 Monte Carlo |
12-25-2013, 11:43 AM | #6 | |
Drives: SRT Yugo GT Super Sport with Manual Join Date: Mar 2012
12-25-2013, 11:46 AM | #7 | |
Let's go Rangers!
I always thought if the chain was stretched you'd burn more then the normal amount of oil. Sent from my AGM, 2SS/RS |
12-25-2013, 12:12 PM | #8 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
I think it's the other way around. Low oil (from whatever cause) leads to timing chain issues.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
12-25-2013, 11:03 PM | #9 |
12-26-2013, 06:12 AM | #10 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
As for the mysterious disappearing oil... that normally leads to a spun bearing and trashed motor...
12-26-2013, 10:02 AM | #11 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Doing short trips in these engines leads to an excess of moisture and gas in the oil which will lead to other issues which I'd guess includes bearing and chains failing. I'd love to know the driving habits of those whose chains went out early. It is a design flaw in my opinion, but if the engine is ran long enough to burn up the gas/moisture during each drive my understanding is that this greatly reduces the chances of failures. But yes...definitely keep an eye on your oil level and don't let it drop.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-26-2013, 12:37 PM | #12 |
check your spark plugs. Somebody had issues with the valve guides wearing out
12-26-2013, 01:16 PM | #13 | |
12-26-2013, 01:54 PM | #14 | |
Interesting, that is the first I ever heard of this one, and I have been following this forum for over 4 years now.
Tags |
burn, oil, v-6 |
