Old 11-25-2017, 05:14 PM   #1
bct10985
Drives: 2010 2SS LS3, 2013 duramax
9.81@143 stock bottom end Ls3
Finally 9's. On pump gas, drove to and from the track, built and tuned by me.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 11-26-2017, 06:44 PM   #2
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Congrats mans, that is a crazy setup !!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 11-27-2017, 01:09 PM   #3
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
Nice passes! I saw ya run. I was up there in my black 6th Gen running.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 11-27-2017, 02:15 PM   #4
bct10985
I only got 1 full pass that day. Let off way early the 1st pass so they wouldn't kick me out just to get some log data. There was a silver zl1 that looked just like my SS there also
Old 11-27-2017, 08:30 PM   #5
kmkalkhoff
Drives: ZL1
Very nice! Get that 60' down in the low 1.4 range or better and you're 9.50's.
kmkalkhoff is offline   Reply With Quote
Old 11-27-2017, 08:43 PM   #6
zfrederick
zfrederick's Avatar
Drives: Black 2010 2ss
Nice job man way to go!!!
the parts never end!!!!!
zfrederick is offline   Reply With Quote
Old 11-28-2017, 04:39 AM   #7
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Congrats Man! Love that MPH
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 11-28-2017, 07:43 AM   #8
bct10985
Its definitely got more in it with a better 60'. Still some tune issues, a lean spike and some KR when i mash the throttle off the line that i need to fix. That should improve my 60' some. I only get one or two runs in before they kick me out for not having a cage unless its a rental day. The track is about to close for the year here. Maybe ill pull the converter and have it loosened up over the winter. This billet ysi is just getting started i cant imagine what it would feel like turned up.
Old 11-28-2017, 10:48 AM   #9
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
Congrats, I love my Vortech YSI, you get your 60ft down and turn it up a little its gonna fly.
MudderFinger is offline   Reply With Quote
Old 11-28-2017, 11:38 AM   #10
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
You picked up 8 mph in the 1/4 since your 10.2 135 slip last month. Awesome! What changed?
Old 11-28-2017, 01:12 PM   #11
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Wow that's moving on stock bottom end and pump gas!!
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 11-28-2017, 02:18 PM   #12
bct10985
I think the 10.2@135 was with the paxton 1500 with 3.33 pulley(15lbs of boost). Switched to billet ysi with same 3.33 pulley(15lbs of boost still) played with tune and went 10.1@138. Put a 3.15 pulley(17lbs of boost) on it and went 9.8@143.
Old 11-28-2017, 02:20 PM   #13
bct10985
Still on a zl1 pump, adm fpcm, boost a pump and id850's. Fuel pressure doesnt drop through the 1/4. The injectors are about maxed out or i would turn it up more
Old 11-30-2017, 10:43 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Nice job!
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
