Old 03-30-2018, 01:22 AM   #1
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Whipped whistle?
After I installed my whipple supercharger, around 1800-2000 rpm in 2nd gear there is a whistle, it’s not the whine, from the supercharger, but a whistle. Can anyone tell me what it is? I’m thinking a vacuum leak, but the car runs great. That whistle is kind of loud. I have cold air intake, would that cause a whistling sound? Or is it normal? Any help will be greatly appreciated.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 03-30-2018, 06:52 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Nothing to be alarmed about we have heard this many times at certain blade openings of the throttle body.
As long as the logs look good your good.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-31-2018, 12:08 AM   #3
tbss1
tbss1's Avatar
Thanks Ted, it was driving me crazy, i thought I had a vacuum leak, or something. I'm glad I went with you for all my mods. By the way can you give me a ball park number of hp, and tq at the wheels with the mods I have in my sig.
Old 03-31-2018, 01:21 AM   #4
DSMer1
Drives: 14 and 15 SS's
620ish to the tire through a auto I'm guessing.
What boost are you seeing with the 3.875 pulley, cam and headers?
DSMer1 is offline   Reply With Quote
Old 03-31-2018, 09:12 AM   #5
JANNETTYRACING
620-640
Old 04-01-2018, 10:58 AM   #6
tbss1
tbss1's Avatar
i have a m6. i'm at 7 with the 3,875 pulley, does that seem right, that's what my boost gauge says. would it be safe to change the pulley and up the boost
Old 04-01-2018, 11:36 AM   #7
DSMer1
Is the boost gauge utilizing obd2 data, a electronic gauge with its own sender or the old school mechanical gauge with a vacuum line ran to the cabin?
I think that's about right with a cam and headers. Mine would peak about 9 with the 3.75" pulley up top but it made a little less down low.
I just swapped the 3.5" pulley on and I haven't went wot yet because it is cold but it is really easy to get to 8psi mid range with a little over half throttle so I think it will make good boost as long as I don't have belt slip.
Safe is a opinion. There are lots of people running a smaller pulley on a stick motor but it is a risk just like your current setup is. It will probably be fine but no one can say 100% because you can have motor problems with a bone stock car.
I wouldn't think twice about going to a 3.75" pulley though. I have one I'm going to be selling in about two weeks.
Who is tuning the car? That is the biggest factor in the question of safe.
Bolt-ons!
Old 04-01-2018, 01:30 PM   #8
tbss1
tbss1's Avatar
I have an AEM gauge, electric with sender, and Ted at Jannetty racing is tuning my car. thanks for all the info.
Old 04-03-2018, 09:55 AM   #9
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Mine does it as well, nothing to worry about
MODS:
Old 04-03-2018, 10:13 AM   #10
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I see that some people are claiming it is normal from the TB at certain times, but have you replaced the TB at all, or removed it? I've heard TB gaskets give off a whistle if they weren't replaced.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
