Rick@Livernois
Old 01-14-2015, 05:52 PM   #1
Cat988h
Cat988h's Avatar
Drives: Rally yellow 2011 Camaro 1SSRS
T56 BOLT ON SEQUENTIAL SHIFT CONVERSION
Looks like a new bolt on sequential shifter has been in development and is being released soon for the tremec T56. Talk is it should be available this year for the TR6060, looks pretty cool thought I would share it with you guys.
http://www.s1sequential.com/t56-sequential-shifter/
ATI Super Damper, Katech C5R Chain, Jannetty 470 Comp Cam, Comp Valve Springs, Mellings Oil Pump, Manley Push Rods, Comp Tringion Upgrade, Cold Air Inductions Intake, 1-7/8 American Racing Headers w Cats, MBRP 3 Inch Exhaust, RX Catch Can, Eaton Tru Trac, 3.91 OEM, DSS Drive And Half Shafts, LPW Diff Cover,3 Inch Noweeds, Amsoil Z-Rod, Tuned by Jannetty Racing
Cat988h is offline   Reply With Quote
Old 01-18-2015, 06:15 PM   #2
LSXBumblebee
LSX Bumblebee
LSXBumblebee's Avatar
Drives: 2014 LSX Camaro
Hmmm...looks interesting. It could be one hell of a upgrade.
LSXBumblebee is offline   Reply With Quote
Old 01-18-2015, 06:25 PM   #3
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
That would be cool
CHMSC is offline   Reply With Quote
Old 03-17-2015, 02:29 AM   #4
Bodywerks
Drives: 2015 2SS/RS/1LE
As long as this isn't the $20k deal that was mentioned in another thread...
I'd be a buyer at around the same price to upgrade exhaust, for example.
His website just says don't get your hopes up on it being like, $600. But was that a sarcastic joke? Or was he saying that it might be, say, double that? I mean, it's just a bolt-on mechanism. If it were a complete modification of the internals of the tranny I could see the price being ridiculous.
If it's in the $1k to $1500 range PUT ME ON THE LIST!!!!
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 03-17-2015, 07:47 AM   #5
Bodywerks
Hmmm, a little more than I expected, but it looks like it's not unobtanium at $2700.
The video looks promising, and if this can still be used as an every day driver-type shifter I'm still interested...
http://youtu.be/gO-ScsLXPoE
2015 SS/RS/1LE
Old 03-17-2015, 08:12 AM   #6
Burt
Cone Killer
Burt's Avatar
Drives: 2012 SS
I'm very interested by this. Not only would you not miss shifts and shift more quickly, but you couldn't money shift either. It would simplify heel-toe shifting a little bit as well. I can get behind this.
2012 Camaro SS - Pedders XA coilovers, Moreno camber plates, Hyperco front springs, 1LE rear sway bar and toe links, JPSS caster locks and radius rod inserts,
BMR trailing arms w/ poly outer bushings and steering rack bushing, and square 19x10.5 Apex EC7 wheels with square 305/30R19 Bridgestone RE71Rs.
Burt is offline   Reply With Quote
Old 03-17-2015, 10:20 AM   #7
Bodywerks
Well, yes and no. I come from an offroading background and I know what you're thinking. If you pull/push hard enough on a dogged sequencer it'll go to the next gear up/down. With this setup you still have to deal with syncro gears. They don't engage unless the clutch is depressed or the engine speed matches the desired gear speed.
So come downshift time, say, coming into a corner at high speed, you will still have to either heal-toe on the downshift to rev the engine or hold the clutch in and press until the transmission will accept the gear change.
A true sequential, say, racing transmission will require a complete transmission redesign. It's out there for the tr6060, but it's a $17,000 upgrade.
This option just simplifies the shifting process - yank to upshift, push to downshift. I think though, that it has the promise to drop at least a couple tenths of the quarter mile for all but the best drivers, and easily improve track times.
2015 SS/RS/1LE
Old 03-17-2015, 10:04 PM   #8
Bodywerks
Also, unlike a true sequential transmission, neutral is in between every gear, not just in one spot, so you could still miss the gear and get stuck in neutral...
2015 SS/RS/1LE
Old 04-01-2015, 09:00 AM   #9
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
thats sweet. but i can buy a new transmission for the price of that.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 04-12-2015, 05:40 AM   #10
Bodywerks
A new 'sequential' transmission? Do Tell!
I'm sure that's not what you meant, though...
It's considered an 'upgrade' to the transmission. We often spend more than the cost of a brand new LS3 crate engine in upgrades to our LS3 engines in our Camaro to get more out of them. I'd bet the average person spends $2500-3k in intake, exhaust, and tunes just to add 50hp to an already 426hp engine. That $3k is half the cost of the engine itself for a 12% increase in power. Yet we justify it.
If this transmission modification were proven to knock, say, two or three tenths off 0-60 or 1/4 mile times, or 2-3 seconds off track times, then it's an upgrade and may be worth it to some.
Me personally, I just like the idea of yanking back hard for every upshift.
2015 SS/RS/1LE
Old 07-03-2015, 11:16 AM   #11
LSXBumblebee
LSX Bumblebee
U wonder how long till this comes out
Sent from my SM-G900V using Tapatalk
LSX 427 | ZL1 Driveline | LSA Blower | Stage 3 BTR PD Cam | 85 lb. Injectors | ZL1 Pump | ADM FPCM | Pulley
LSX Bowtie Block Blueprinted by Gilroy Automotive Machine | Assembled by LSXBumblebee/Arnold Crocker
Build Thread: LSX_Bumblebee's 2014 LSX Camaro 2SS/RS Convertible
Old 07-03-2015, 12:40 PM   #12
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Almost feeling like a liberty!!! I can't wait.
BFASTNOTLAST is online now   Reply With Quote
Old 07-03-2015, 12:45 PM   #13
jrhagen
Banned
Drives: Camaro
Waiting
jrhagen is offline   Reply With Quote
Old 09-23-2015, 06:26 AM   #14
Bodywerks
They sent me this video of it being used on the road in a worn out transmission with a crappy clutch. They commented that the shifts would be faster and smoother on a less used up gearbox. But the shift speeds here are pretty impressive!
2015 SS/RS/1LE
