#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Wheels | Tires -- Sponsored by The Tire Rack
BeckyD @ James Martin Chevy
Old 11-25-2016, 12:45 AM   #1
Camaro1LTBA
Drives: 2016 Camaro
Question Tire Rotation for a 2SS?
I have a 2016 2SS with the oil change light on and for some reason I thought that the 2SS doesn't require any tire rotations. I did post in the mechanical section, but taking the car in for an oil change and the less visits to the dealership the better!
Per the manual, the tires should NOT be rotated if there are directional arrows or marked R or L. My previous Gen5 was a base model 6... just thought I might be able to get a quicker answer as I'm already going in for the oil change and would like to have everything done at once there.
Will leave them a message tonight or call first thing when they open to see if they can rotate the tires while the car is there. For some reason I thought that the 2SS didn't need a tire rotation. Feel free to correct me! Any help would be appreciated! Thanks!!!
TL;DR - Does a 2016 2SS require a tire rotation???
Thanks again!
2016 Camaro 2SS Manual
Hyper Blue/Ceramic White
Nav, MRC, NPP, Black 5 Spokes
Escort MAX 360
Camaro1LTBA is offline   Reply With Quote
Old 11-25-2016, 01:08 AM   #2
Hekate1
Hekate1's Avatar
Drives: 2020 2SS 1LE
If u have the stock Goodyear F1's asymmetrics they are unidirectional as well as wider on the rear than the front. So no, they cannot be rotated.
Hekate1 is offline   Reply With Quote
Old 11-25-2016, 01:17 AM   #3
Camaro1LTBA
Drives: 2016 Camaro
Thank you so much for the quick response! Appreciate it... and the less the Service Department has to do, the better!
Stock 2016 2SS with Black 5 spokes. Thanks again! :-)
Escort MAX 360
Old 11-25-2016, 01:24 AM   #4
Hekate1
Hekate1's Avatar
Ur welcome!
Old 11-25-2016, 06:25 AM   #5
raptor5244
Drives: 2022 CT4-V Blackwing
The stock Goodyears on the SS are not directional. If you look at the sidewall there are no arrows to indicate direction. Therefore, they can be rotated side to side if you want. Obviously, you can't rotate from to back to front since they are different sizes.
2002 Corvette Z06 - Black - Sold
2013 Camaro SS 1LE - Black - M6 - Sold
2016 Camaro SS - Mosaic Black - A8 - Sold
2017 C7 Stingray - M7 Coupe - Sold
2019 C7 Grand Sport M7 Vert - Sold
2021 Camaro ZL1 - Black - A10 - Sold
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
raptor5244 is offline   Reply With Quote
Old 11-25-2016, 06:56 AM   #6
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
Rotate from side to side ONLY!!!!!!!
Drags1998 is offline   Reply With Quote
Old 11-25-2016, 07:18 AM   #7
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
this
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 11-25-2016, 08:41 AM   #8
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
Why would you need to rotate rotate side to side? If there is more wear on one side vs the other, sounds like some alignment check is needed to me..
BrianL is offline   Reply With Quote
Old 11-25-2016, 09:03 AM   #9
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
Originally Posted by BrianL View Post
What would you need to rotate rotate side to side? If there is more wear on one side vs the other, sounds like some alignment check is needed to me..
if the tires are not directional then you need to rotate side to side. This keep the tread blocks from cupping on the edges which can cause wear issues and or early death to the tires.
TJay74 is offline   Reply With Quote
Old 11-25-2016, 09:23 AM   #10
Camaro1LTBA
Drives: 2016 Camaro
OK... so that went backwards quick lol. So I do need to get my tires rotated.
I trust you guys more than the dealership which is why I originally asked here. The only thing I found in the manual was don't rotate directional or marked tires.
I'll let you know what the dealership says in a few minutes (I have a decent rapport with the Service Department Manager so will let ya know).
I'm not sure I see a point in the side to side, but I'm literally just waking up and will read the post on the wear if not rotated again.
Thanks again! Although I went from cool that's what I thought to confused lol.
Escort MAX 360
Old 11-25-2016, 09:53 AM   #11
Camaro1LTBA
Drives: 2016 Camaro
Update: I wasn't able to talk to the Manager, but he'll be in Monday so will bring the car in on Monday morning for an oil change and tire rotation.
The lady I spoke to said if they're not directional, but wider in the back (which she believes is the case with the SS) they will rotate them side to side as was mentioned here.
Glad I asked as I was under the impression that they shouldn't be rotated as it seems a few other members were as well.
Thanks for the heads up otherwise I wouldn't have bothered and would have just had them change the oil and pump up the tires a bit more.
Escort MAX 360
Old 11-25-2016, 10:05 AM   #12
Camaro1LTBA
Drives: 2016 Camaro
Not sure if this was directed towards me, but just following the manual on the oil change (light is on) and it is due for a tire rotation per the manual.
I was originally under the impression that the stock SS didn't need a tire rotation, but the manual says not to rotate only if the tires are directional or marked... and I don't see either.
Looks like the side to side posts along with the dealership confirmation both agree that I'm due for a tire rotation, but only from side to side. Now I'm questioning if this is even necessary.
Gotta love being a fanatic and obsessing over every detail lol.
Escort MAX 360
Old 11-25-2016, 04:15 PM   #13
Hekate1
Hekate1's Avatar
Wow my bad. Sorry. I was going by what the dealership told me. Ugh!
Old 11-25-2016, 04:58 PM   #14
mulletman
Drives: 2017 Camaro SS
Tires do not always wear evenly even if the alignment is correct. Rotating from side to side helps even the wear. The first two rotations are free and do not hurt anything. I rotate between 6,000 and 8,000 miles.
mulletman is offline   Reply With Quote
