12-10-2018, 03:29 AM | #1 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I Need List of NGK 6 Heat Range Spark Plugs
I Need List of PN #’s for NGK 6 (1 step colder than stock) Heat Range Spark Plugs.
All these, but in 6 heat range..... Because NGK doesn’t have a good cross reference chart for changing heat ranges. Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
12-10-2018, 05:48 AM | #2 |
Drives: 2012 ZL1 Redline Phase 4 Join Date: May 2017
I'm not sure I understand what your asking but I run TR6's on my 2010 2SS/RS Supercharged L99 Camaro
NGK # 4177 TR6 V-Power
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
12-10-2018, 07:47 AM | #3 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Edit: for some clarification: TR5 = heat range 5 plug. The ones in the picture are all heat range 5 plugs I believe TR6 = heat range 6 plug TR7 = heat range 7 plug
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 12-10-2018 at 08:26 AM. |
12-10-2018, 08:21 AM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Google is your friend.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
12-13-2018, 06:34 AM | #5 |
LSx FTW!!!
I'm more or less looking for Iridium IX for LS3/L99 in #6 and #7 heat ranges.....
Who has the PN#?
12-13-2018, 03:41 PM | #6 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Try search engine for TR6IX.
12-13-2018, 07:06 PM | #7 |
I've heard Google has them
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
12-13-2018, 08:12 PM | #8 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
AcDelco 41-104 are 6 heat range and Iridium , used on ls9 motors
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
12-13-2018, 09:28 PM | #9 | |
LSx FTW!!!
Thanks! Sent from my iPhone using Tapatalk
12-18-2018, 07:28 AM | #10 |
LSx FTW!!!
Couldn't find any local shops with #6 heat range NGK's nor the ones recommended here.
Friend had a set of TR7IX's for his CTSV on the shelf so we gave them a try. They're working great so far! Surprised me that a 2 step colder plug doesn't run crappy. From my dirtbike days, too cold of a plug would run like it had water in the gas or something. These run clean and crisp with my setup n/a.
12-18-2018, 09:55 AM | #11 |
Drives: 2011 Camaro 2SS Join Date: May 2016
I just got done swapping mine to a TR7IX plug as well, although I'm boosted I was running a TR5IX, the difference is night and day, car is running stronger than ever
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
