Old 07-11-2018, 12:38 PM   #1
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
LG Motorsports wheels
I installed some LG Motorsports ZL1 replicas this week and I've noticed the vehicle feels a lot different, does anyone know if these are a lot heavier than the OEM ZL1 wheels? i expected the wider fronts and rears to add some heavier feeling in steering, but even over small imperfections in the roads the car thuds and feels so much heavier
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 07-11-2018, 02:39 PM   #2
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
This may not be completely the same situation: I went from the stock 19" wheel (I dont recall the width) to an aftermarket 20x10 wheel. I'm sure there was a weight increase but at the same time I went from a 245/55R19 tire to a 285/35R20 tire, which I attribute the shorter profile difference in the thud experienced when hitting those road imperfections. I was rather surprised at how loud and shocking the thud is now compared to what it used to be.
P.S. I have to edit my signature block to include the different wheels ; )
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 07-11-2018, 04:19 PM   #3
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
if your wheels are cast going wider plus the additional meat on the tire it would definitely add weight and effect the performance of the car.
Our Flow forged wheels FS01, FS02, FS06 and even our reps that are flow forged like the M017, M716 and new M755 will all save you a rough estimate of about 4-5lb per corner even going 20x10 with the wider tire compared to factory 20x8.5 or 9.5
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 07-12-2018, 11:21 AM   #4
HOTCIVIC
HOTCIVIC's Avatar
Drives: Camaro
I just purchased these and they should be here in a few days.
Question - does anyone know if the GM 1LE bowtie center caps will fit these? I asked the LG rep and he said "they should" fit but he didn't sound too confident.
I've searched the forums but for some reason a lot of the LG ZR28 threads have been locked or purged.
HOTCIVIC is offline   Reply With Quote
Old 12-08-2018, 04:33 PM   #5
LETHAL2SS
LETHAL2SS's Avatar
Bump for the thread, I'm installing some newer tires in the next coming weeks and will see if maybe the runflats on the rear are whats causing it to feel the way it does,(most likely the case) but the problem still persists.... I've looked for posts about the weight differences and haven't found any concrete info.
