12-22-2020, 10:00 AM | #1 |
Drives: Chevrolet Camaro LS Join Date: Jun 2020
Steering Noise on 2012 V6 LS
I was curious if any other 5th Gen Camaro owners have experienced what I am feeling through my steering wheel. If after driving the car at highway speeds for longer than 30 min I feel a slight rubbing sensation through the steering wheel when I quickly move the wheel back and forth 3-4 inches. The sound doesn't seem to be metallic in nature but sounds and feels softer like plastic or hard rubber rubbing together. The sound seems to be coming from inside the rear of the steering column. If I park the car and have the engine off it does not produce this sound but does produce a feeling of backlash in the steering gear with the same motion. When the engine running on I do not feel this backlash in the steering gear.
Has anyone else experienced this? Any ideas what could cause this? The car has 60,000 well cared for miles on it. It was a garage car that was not driven much over the past 9 years. |
12-22-2020, 10:16 AM | #2 |
Drives: Camaro Join Date: Jun 2020
I have the same noise which I believe is the rubber boot where the steering shaft enters the firewall. The engine runs so quiet you hear every little thing. Mine has done it for the the past 100k miles, sometimes loud sometimes it goes away. Never really concerned me, nothings perfect especially a car. Now the creaking frt and rear steering bushings bug the crap outta me!
12-22-2020, 08:47 PM | #3 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Might be a dumb question, but have you checked your fluid level?
"Make yourself sheep and the wolves will eat you"
12-22-2020, 11:33 PM | #4 |
12-22-2020, 11:37 PM | #5 | |
12-23-2020, 08:50 AM | #6 |
Actually they are heavy cars overall. The reason you hear everything is the car is built so quiet. I've never owned a car as quiet as this. All the 4th gens I owned you couldn't hear a freight train in a nitro glycerin plant over the sound of the car. Especially on a cold start. The last WS6 I owned was priceless, noisy rattly loud was a real trip to drive. Loved every min of it! In this 5th gen I can hear everything, even the creaking bushings in the frt and rear. Bushing were gone in the back end of the WS6 from wheel hop and you couldn't hear them unless the car wasn't running.
12-24-2020, 07:20 AM | #7 |
Drives: 2012 Camaro SS L99 Join Date: Apr 2012
It's the rack and pinion. I had the same exact problem. I tried every solution I could find and replacing the rack was the only solution and 1.5 years later still have none of the old issues. Changed rack myself wasn't too bad to do.
12-24-2020, 07:47 AM | #8 |
I would suggest you flush the power steering with Dexron IV before doing anything else. The power steering fluid takes a beating and needs to be changed every few years. Dex6 is about the best fluid you can put in there. My steering was starting to feel notchy and funny in a steady turn after changing the fluid it works fine again. I still have the noise at the rubber but that may not be your issue.
12-26-2020, 10:08 AM | #9 |
It sounds and feels like rubber but trust me if you have a non electrical rack the only solution is to replace the rack. Others have had the same issue hopefully some will jump in and share their experience. I did mine myself since warranty was up and got a brand new rack org equipment rack for $280 with free shipping from Amazon. Just trying to help I wasted a lot of time and money trying other solutions to avoid replacing rack since car only had $36k (age out of warranty) at the time but replacement was the only solution and wished I replaced it much sooner. I'll shut up now just trying to help.
12-28-2020, 11:36 AM | #10 | |
