08-01-2020, 07:22 PM | #1 |
Drives: '21 ZLE A10 Join Date: May 2012
Transmission Fluid Alternative for the A10...Amsoil!
I know this post won't be met with much confidence but there is an alternative to the GM ULV for our A10 transmissions. Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid by Amsoil is the answer. Their page lists this fluid as approved for use in the 10 speed automatic for GM and Ford.
With their "easy pack" quarts, it is actually simple to add the fluid when it is time. Of course you have to add the fluid through the little fluid check orifice which is a PITA. Buy 8 quarts but my suggestion is to use 7 to begin and adjust from there. Do not overfill this transmission! Yes, I am using this fluid now but didn't want to post until I was the "guinea pig" and had at least a track day under my belt. The transmission behaved flawlessly and I never had any problems whatsoever. The temps were nearly the same but I was at a different track. I don't have an apples to apples comparison for temps. Below are a few pics from the Amsoil site for reference...I hope this helps someone as this stuff works great!
08-01-2020, 08:09 PM | #2 |
Drives: 19' ZL1, BMW F80 M3 Join Date: Jun 2016
Did you paddle shift or leave it in auto when tracking it?
08-01-2020, 08:44 PM | #3 |
I like to use the paddles. In "D" the car sometimes hunts or upshifts at bad times. Some swear by the automatic shifting algorithm but I am not a fan. The ZL1 1LE may have a different program.
08-02-2020, 09:31 AM | #4 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Thanks for the tip, and I'm a believer in Amsoil products, but when I need a trans fluid change I'll get it flushed at a reputable dealer and of course they only use what the service manual calls for
Not a fan of partial drain and fill. The torque converter needs to be flushed out. |
08-02-2020, 09:37 AM | #5 |
Drives: 2019 SS Join Date: Apr 2020
What's wrong with the GM fluid?
08-02-2020, 09:50 AM | #6 |
nothing...just wanted another option and I like Amsoil products
08-02-2020, 11:43 AM | #7 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Ok, I'll say it.........
Juice box? LOL. makes sense less space.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
08-02-2020, 01:18 PM | #8 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Thx Stephen, it's good to have options
08-03-2020, 10:30 AM | #9 |
Drives: 2018 Camaro SS Join Date: Sep 2009
Good point. That ran though my mind when I changed the fluid on my A8. I changed the oil in the pan and replaced the filter. Next, I drove it around town to mix the fluid up. Got back home, and swapped the oil in the pan one more time. I have heard of bad experiences with flushes and wanted to DIY. I suppose if twice wasn’t enough, it could be done again. I’m comfortable with it though
08-03-2020, 11:00 AM | #10 |
Drives: 2018 ZL1 1LE NFG Coming Join Date: Apr 2017
I used this for my Z07 with A8 and dont have any problem with it. This is a lower viscosity ATF and match OEM ATF's viscosity.
I don't know what the A10 calls for viscosity tho, so you need to double check to make sure. It might be too thick. |
08-03-2020, 11:47 AM | #11 | ||
Flushes are always superior *IF* you keep up with the service intervals. Flushes can cause more harm than good in the case of older transmissions that haven't been serviced and the fluid is already shot. See this video at 2:45 in |
08-03-2020, 12:45 PM | #12 |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
Stephen12ZL1 -
When you are tracking the car, what are your trans fluid temps like? Do they peak and hold, or are they constantly increasing? Mine slooooowly climb (30+ minutes) to 200-205 degrees F on the street in 90 degree ambient temps. |
08-03-2020, 04:53 PM | #13 |
they slowly climb in my experience...the longer on track the hotter it gets...especially if the circuit is tight and lots of shifting occurs. Max is 230 or so when ambients are 93-95°. Summit Point Main is worse than VIR Full for transmission temps. Lap times are 1:22 at Summit Point vs 2:03 at VIR with two long straights at VIR to allow cooling.
08-03-2020, 04:54 PM | #14 |
This Amsoil is approved for ULV service as per the info above in the pics.
