02-28-2021, 11:58 PM | #1 |
Drives: 2018 Camaro ZL1 Convertible A10 Join Date: Mar 2012
2018 ZL1 low trap speed
Hello all,
I bought a 2018 ZL1 A10 Convertible about 2 years ago, and decided to take it to the drag strip at PBIR today (I haven't been to a track in over a decade). Granted it's more of a beach car....but I wanted to see what it did. It has 31,000 miles. I have a Rotofab, Phastek lowering springs and forged wheels in a stock size that weigh the same as the stock wheels (running fresh Goodyear Supercar F3s at 32 psi). Other than an NPP fuse pull, it is otherwise stock. My best run was my first (I only had time to run twice and I spun the second time) was my best: Conditions when I ran at 11:00 a.m.: 83.21 degrees, 61% Humidity, 30.22" pressure. 21' track elevation. This works out to: Density Altitude: 1560 feet Relative Density: 95.51 % I did a short burnout and used launch control (1,200 RPM, 12% slip). I ran: R/T .211 60' 1.852 330' 5.065 1/8 7.700 MPH 93.27 1000' 9.969 ET 11.894 MPH 117.07 My question is simple: am I imagining, or is that MPH really low? Any thoughts on what to check (I saw a video on purging supercharger coolant, so I will look into that first). Thanks.
Ed 2018 ZL1 A10 'Vert
03-01-2021, 06:32 AM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Is it possible you're lifting a little early on the top end of the track? its not the best of track conditions due to the temp and humidity but I would have thought your trap speed should be just a little higher even in those conditions, low 120s.
03-01-2021, 08:49 AM | #3 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
It doesn't look like it based on his 1/8mi trap. It's low through the entire run. It's a convertible which is heavier and it might be closing throttle to reduce torque. I would check to make sure the air is purged from the IC system and maybe even try mixing in some 100 octane.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
03-01-2021, 03:52 PM | #4 | |
03-02-2021, 08:00 AM | #5 |
Drives: ZL1 Mosaic Black Join Date: May 2016
I was there with you...the Toyota guy!!!
I remember your coolant in your tank was low. I know the coolant route/storage for the sc is different, but its possible air in the sc is causing it to pull timing. It takes a special tool to refill coolant and eliminate all of the air from the supercharger...the dealership has it unfortunately.. |
03-02-2021, 08:42 AM | #6 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
03-02-2021, 08:52 AM | #7 | |
I know Edwin320 is going and so will a bunch of other camaros and chevys. |
03-02-2021, 09:22 AM | #8 | |
Drives: '18 ZL1 1LE Join Date: May 2020
https://www.dedicatedmotorsports.com...-p/lt4capv.htm
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
03-02-2021, 11:14 AM | #9 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Yep, the ADMv2 reservoir tank that’s discounted on the group buy right now. Bleeding the system couldn’t be any easier. Just take the lid off with the engine idling.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
03-02-2021, 12:21 PM | #10 | |
03-02-2021, 12:28 PM | #11 | |
Yes, my coolant was low. I filled both tanks to the appropriate fill line yesterday. I'm pretty sure I felt it pull timing. It was noticeable. I suspect there is air in the sc coolant system. I bought that little adapter linked above (hopefully I get it before next weekend). I also have a fused jumper that I'm going to use to activate the sc water pump. I'll pull the front wheels up on my ramps to elevate the front of the engine, and purge it from home. I have a feeling its going to need it. I may go back on 3/12 if I can get off from work.
03-02-2021, 12:48 PM | #12 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
If this is your issue. You might as well go and buy a supercharger coolant reservoir to stop this from happening again.
03-06-2021, 06:15 PM | #13 |
So I received the adapter from Dedicated Motorsports, cut a 2 liter bottle in half, and figured out which connector to jump at the fuse box to turn on the supercharger coolant pump, and I purge the air from the system. There was a huge amount of air to be purged.
Now I just need to test the car to see if it worked.
03-06-2021, 08:15 PM | #14 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Which spot did you jump for the supercharger Coolant pump?
