01-21-2017, 08:57 PM | #1 |
Drives: 2016 4 cylinder 2.0t Join Date: Dec 2016
What to do?
So I've had my car for 3 months now, and made a bunch of changes. I change the tail light, new exhaust, and tinted my lights. What else should I do? Leave comments below.
Also put go pro mounts on my car. Vids coming soon. |
01-21-2017, 09:00 PM | #2 |
Drives: ^^^This Join Date: Nov 2015
Front fascia extension, cold air intake, lowering springs, paint calipers...that should keep you busy for now
01-21-2017, 10:39 PM | #3 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
You need performance modifications...
01-21-2017, 10:41 PM | #4 |
01-22-2017, 12:22 AM | #5 |
Drives: 2016 Camaro LTG Join Date: Jul 2016
E85 tune. Sway bars. Sticky tires.
2016 LTG Camaro in Hyper Blue with MRT V3 Catback and Brembo SS Brakes.
01-22-2017, 12:37 AM | #6 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Don't forget the trunk monkey.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
01-22-2017, 01:21 AM | #7 |
[QUOTE=Nate...;9518283]E85 tune. Sway bars. Sticky tires
What the E85 tune |
01-22-2017, 11:18 AM | #8 |
603 Camaros
E85 / flex fuel it's better for your far supposedly. You probably have plenty of E85 stations in your area.
01-22-2017, 11:23 AM | #9 |
E85 is gasoline with a higher ethanol content. It also has a higher octane rating. This means with a working flex fuel sensor and a custom E85 map in your tune you can make significantly more power with no hardware changes.
01-22-2017, 03:22 PM | #10 |
01-22-2017, 04:45 PM | #11 |
Drives: 2016 Chevrolet Camaro LT Join Date: Oct 2016
How much does an E85 tune run for?
01-22-2017, 07:02 PM | #12 |
603 Camaros
Depends on the company and what you want to do you'll need the E85/Flex Fuel Kit known ones go anywhere.
RPM Motorsports sells a kit with Tune for $499. Vermont Tuning sells it for $349 not sure on a performance tune he likely just turns the stock E85 tables on in the existing stock tune. I'm sure most speed shops can put a kit together for you it's the tuning to fully utilize E85 that will cost you. You also need to take into account the year of your Camaro 2016 your good to go but 2017 the tuning process is much more involved because of added security by GM.
01-22-2017, 08:53 PM | #13 |
Drives: 2016 Nightfall grey 2.0 1LT Join Date: Aug 2016
Why did GM add more security on 2017 ? They don't want us to use the E85 fuel dispite the fact that the tables are already in the ECU.
01-22-2017, 10:02 PM | #14 | |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
Most OEM's don't use flex fuel on boosted applications. I know for a fact that running E85 with a good tune up on an ATS will exceed the max torque rating of the 6L45 trans, and I'm pretty sure that it also exceeds the max torque rating of the M6 3150 in the ATS as well. Also, boosted applications need a DIALED IN tune. Meaning, that tune has to be spot on due to the very wide quality of "E85" fuels out there. E85 can be very beneficial, but it is not for n00bs. The amount of ethanol and the actual "E" rating can vary. Just because the pump says "E85" doesn't mean that's what you're getting. Many factors come into play such as the quality of the fuel, how long it's been stored at the station, and the current ambient temperature. We have tested pump E85 fuels down to E45! You'll NEVER get true E85 in the winter, as it needs to be blended with more gasohol so it doesn't absorb too much ambient water. Should I keep going? Or have I you already? I've always said you need a GOOD tune. I stand by that, doubly so when it comes to running E-fuels. I have yet to see any tuner with a comprehensive E-fuel tune, and don't expect to see one ever, as it would require an OEM only amount of dev time. |
Tags |
camaro, chevy, taillights |
