Old 10-24-2017, 12:48 PM   #1
Stud45thSS
Stud45thSS's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Project Flash
Well considering my 45th comes with carbon flash paint guess I'll nickname her the flash.
Started with a bone stock 45th anniversary I purchased with 6,800 miles
Current plans are to keep it a mild street car as I already have a SRT4 I Primarily use for drag racing.
Installed some Speed Engineering Long tubes over the weekend and am thrilled to have a throaty v8 exhaust note once again.
Ordered a RotoFab cold air intake which will be here Thursday and installed.
Next will be cams which I am looking at BTR Stage 3, open to suggestions trying to maximize horsepower but retain drivability.
Stud45thSS is offline   Reply With Quote
Old 10-25-2017, 10:01 AM   #2
Stud45thSS
Stud45thSS's Avatar
Decided I was tired of the added heat soak from all the plastic covers so I removed them now just to get some other things cleaned up in the bay
Old 10-25-2017, 02:06 PM   #3
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
Nice 45th and welcome aboard!
Yep, the mod bug has bit you early, but I can sympathize. I had mine a total of 24 hours before the mods began. Now, 6 months later, I shipped her off for more power. LOL!
What are you going to do with all those wires?
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 10-25-2017, 03:37 PM   #4
Stud45thSS
Stud45thSS's Avatar
The plan is to do a wiretuck and hide as much as I can without extending the harness by hand. Maybe eventually. But for now I am going to relocate the coils and get some valve covers and fuel rails to distract you from looking at all the wires till that gets done
Old 10-25-2017, 03:43 PM   #5
Stud45thSS
Stud45thSS's Avatar
After a nice washing of the engine bay to remove all the dust and such.
These are the places I would like to work on the most the coils, figure out what to doin the area of the fuse box, and the harness laying on top of the heads.
Old 10-27-2017, 09:09 AM   #6
Stud45thSS
Stud45thSS's Avatar
RotoFab CAI came in and was installed. Now just need to clean the wires up and hide everything
Old 10-29-2017, 12:38 PM   #7
Stud45thSS
Stud45thSS's Avatar
Did some wiretucking
Put the injector harness under the fuel rails, the EVAP line under the throttle body. Is there a better place to move the EVAP to?
Old 11-02-2017, 11:14 AM   #8
Stud45thSS
Stud45thSS's Avatar
Installing these as soon as they get here. I like a clean engine bay and figured these would clean it up a bit and look nice
Old 11-04-2017, 11:29 AM   #9
Stud45thSS
Stud45thSS's Avatar
Got my Holley valve covers installed did some more wire tucking and cleaning up. But here is how the valve covers look
I still need to do the fuel rail flip as well to clear up some more clutter
Old 11-10-2017, 02:00 PM   #10
Stud45thSS
Stud45thSS's Avatar
Got my fuel rail flipped around only cussed a few times. Dropped a clip into the heat shield had to fish it out, then forgot I needed to disconnect the EVAP line and when I tried to undo it with tension I broke one of the gm quick disconnect lines so guess I'll replacing and tucking that line with some hose and clamps
2012 2SS 45TH LS3 M6
MODS: Speed Engineering Long Tubes, RotoFab CAI, Holley Valve Tall Valve Covers.
Stock Dyno: 380hp 386TQ
Headers and CAI: 425HP 434TQ
Old 11-19-2017, 12:40 PM   #11
Stud45thSS
Stud45thSS's Avatar
Bone stock Dyno 380HP 386TQ
Old 11-19-2017, 12:41 PM   #12
Stud45thSS
Stud45thSS's Avatar
After headers and cold air and tune
425HP 436TQ
Will post Dyno pic tomorrow
Old 11-20-2017, 08:15 PM   #13
Stud45thSS
Stud45thSS's Avatar
Base pull vs headers, cold air and tune pull
Old 11-24-2017, 06:49 PM   #14
Stud45thSS
Stud45thSS's Avatar
I came over from fwd platform that had a serious wheel hop issue so I know how much damage can be done if you don't keep the power planted to the ground so to help with that I am ordering "aFe Control PFADT Series Rear Tie Rods/Trailing Arms Package; Chevrolet Camaro 10-15" and soon after the solid rear subframe mounts so I won't need to worry when I get to a more serious power level
