Old 12-13-2017, 02:30 PM   #1
asand1
Drives: 2015 V6 6MT
2015 1LT Daily Driver
Almost a year ago I purchased my 2015 1LT and started making small changes to it. It is my only vehicle and there are no raceways around here so its mostly cosmetic with a little functionality.
1st mod was spline drive Gorilla lugnuts.
Next I added Phastek fogs
asand1 is offline   Reply With Quote
Old 01-11-2018, 02:58 AM   #2
asand1
Drives: 2015 V6 6MT
Installed slotted/drilled Brakemotive Rotors and cermic pads for front and rear.
Old 01-11-2018, 02:59 AM   #3
asand1
Drives: 2015 V6 6MT
Ordered an Elite E2-X catch can with single exit.
Old 01-11-2018, 06:40 AM   #4
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
You have a very nice looking ride be proud of her and she will treat you well for many years to come.
I just installed the Elite E2X system on my 2LT/RS. This kit has the two exit ports as well as the clean side system. Without any meaningful directions the install was a tad tricky until some folks helped me out. I did not care for the way Elite had you installing the "barb" for the second exit port into the plastic elbow in front of the throttle body. I ended up drilling and installing a permanent heavy rubber grommet, now you can push a 45 degree elbow into the grommet and it's SECURE. I ended up doing a few of these modifications for other friends. I still have one system left if anyone decides to go with the duel exit ports.
Bottom line I am very happy for you and you sound so thrilled and proud. way to go!
Deputy347k9 is offline   Reply With Quote
Old 01-11-2018, 02:04 PM   #5
KJZ28
KJZ28's Avatar
Drives: 2018 Buick Regal TourX
I like those lugnuts. Nice car, thanks for sharing.
SOLD: 2010 2SS/RS L99-A6 K&N CAI, Speed Engineering Long Tube Headers, Stainless Works hi-flow cats, Flowmaster American Thunder Cat-back. Tuned by Corvettes of Westchester. 1/LE rear suspension conversion, Bilstein B6 Stuts/shocks.
KJZ28 is offline   Reply With Quote
Old 01-20-2018, 01:51 AM   #6
asand1
Drives: 2015 V6 6MT
Installed the catch can. I cut the rubber hoses to short to be able to fit the engine cover, and I don't like the tight fit between the intake and wiring harness. My concern is that the can could wear a hole in the intake and cause a lean condition, or it could wear into the harness.
Old 01-20-2018, 02:55 AM   #7
asand1
Drives: 2015 V6 6MT
To make more room for the catch can and give me access to empty the can, I ordered an Airaid 250-915.
Old 01-25-2018, 05:46 PM   #8
asand1
Drives: 2015 V6 6MT
This mornin I installed an Airaid MIT to clean up the engine compartment and make room for the oil catch can.
