12-29-2017, 11:26 PM | #1 |
Drives: 2018 HB ZL1 M6 Join Date: Apr 2009
New ZL1 under carriage covered in salt...
I was excited that my ZL1 built and delivered mid December. Picked up from dealer a week ago and drove straight home.
finally get to check out the car and found under carriage of car completely covered in salt... there are noticeable amount of rust through out exhaust. Especially the coupling part... and all the aluminum bar/support/ panel are corroded. Should I address this issue to dealer or gm customer service? The car is literally 2 weeks old... kinda disappointed. I guess I will be looking for good car wash that will wash underneath of the car. |
12-29-2017, 11:56 PM | #2 |
Drives: 6th. Gen ZL1 Join Date: Jan 2017
12-30-2017, 12:28 AM | #3 | |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
12-30-2017, 06:53 AM | #4 |
Drives: 2010 Camaro 2ss procharged Join Date: Apr 2015
Most car washes do the undercarriage spray. But I still would notify the dealer
12-30-2017, 09:19 AM | #5 |
Thank you all. I just opened a case with GM and notified dealer. Will wait and see after holiday what GM say
12-30-2017, 09:29 AM | #6 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
That would have been a deal breaker for me. I would get a compound like KROWN rust proofing put on it to keep it from getting any worse.
https://www.krown.com/products/aeros...and-lubricant/ https://www.krown.com/products/aeros...lt-eliminator/ Hope that helps. |
12-30-2017, 10:36 AM | #7 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I used to be so worried about that type of stuff to the point, it wore me out worrying all the time. There are some guys here that drive these cars years round, even in snow. These cars were made for this climate. Heck my last GEN5 car was a fleet car for GM...driven in detroit for part of a winter. The car looked brand new underneath for the most part, and the price was right. I blasted it off underneath with a power sprayer and never looked back.
My advice is to get the salt off as soon as you can with a good under body wash. And enjoy the car.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
12-30-2017, 04:37 PM | #8 |
Drives: '17 ZL1 Join Date: Jul 2016
Really sorry to hear that. I know exactly how you feel. I'm not sure what GM has going on, but this corrosion is not normal. Simply being exposed to the elements for a few weeks while in transit shouldn't cause that type of corrosion.
The ZL1 1LE in the link that was posted was going to be mine. It was in really bad condition too, so I left it at the dealer. I bought a new 2014 GMC Sierra in June of '14. It's my daily driver, and it's exposed to salt throughout the winters here in WV. It has almost 40k miles, and you could count on one hand how many times I've washed it. It's still in better shape underneath than that ZL1 1LE was with 3 miles. You are doing the right thing by creating a case with GM. This needs fixed, and there's no chance of it being fixed if people accept these cars as-is.
12-30-2017, 04:40 PM | #9 |
Drives: 1970 chevelle Join Date: Aug 2011
I won't accept mine if it comes in like that. Hopefully it won't but only time will tell
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
12-30-2017, 10:46 PM | #10 |
I appreciate all the replies. At this time, I took some pictures of under carriage of the car and went ahead got a bucket of warm water mix with simple green and wiped what I can get to under the car. It looks much better. The car still need to run through one of those touch less car wash with under carriage spray.
12-30-2017, 11:04 PM | #11 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
https://www.ammonyc.com/shop/ammo-boost-winter-wash/
Have any of you used this before? I don’t live in a snowy area but it works great and I can tell it works by not turning my rotors rusty after a wash |
12-30-2017, 11:14 PM | #12 |
Never use that before. Might check it out.
I ordered some salt away spray from amazon. Will try that first. |
12-31-2017, 02:59 AM | #13 |
Drives: Grandad's C2 L89 Join Date: May 2017
Subscribed and concerned.
Isp, can you post pics?
2018 ZL1 1LE sw/PDR
12-31-2017, 08:24 AM | #14 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Need to remove salt? Just use plain water.
The best thing for removing salt is plain clean water. But if you want to spend more money and spray something to make you feel better, go for it.
Salt Away contains (from their MSDS): 70-90% Distilled water, which removes salt. Plus pixie dust to make you feel good: 5-10% surfactant, 5-10% corrosion inhibitor, 5-10% non-hazardous coupling agent, none of which remove salt. MSDS Ref. One of AMMO's claims: "neutralizes" salt. False. Salt is already neutralized by definition (NA neutralizes CL one to one). The water in it will dissolve salt deposits, just like the water from your tap. For removing aluminum oxide corrosion there are chemicals out there containing phosphoric and hydrofluoric acids. Alumabright cleaner looks promising, but it's probably really bad for anything anodized and everything else on your car, but most I found require some mechanical agitation. Don't get it on your bare skin or you'll regret it. MSDS REF http://www.envirotechcoating.com/pro...minum-cleaner/ Last edited by Gunkk; 12-31-2017 at 08:34 AM. Reason: added msds refs |
