02-29-2024, 02:24 PM | #1 |
Drives: 2013 Chevrolet Camaro 2SS/1LE/RS Join Date: Dec 2023
Cam Swap Quote - Is this accurate?
I reached out to a local shop and they provided me with this quote. Is this accurate or overpriced?
02-29-2024, 03:53 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
That's competitive pricing.
02-29-2024, 05:02 PM | #3 |
Drives: 2013 zl1 vert Join Date: Dec 2018
seems reasonable.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
02-29-2024, 06:59 PM | #4 |
Drives: Camaro 2SS Gen 5 Join Date: Oct 2023
Whats the goal??
02-29-2024, 08:33 PM | #5 |
Here is my original quote request:
To whom it may concern, I am reaching out to request a quote for my 2013 Camaro SS 1LE to swap out the cam, valve springs, push rods, supporting bolts and gaskets, and would like to hear of any other suggestions to replace while swapping it as well. I'd like to put a big cam in it that has a significant lope. Of course I would need a dyno tune included as well. I only need it tuned on 93 as I am not running E85. It currently has a Cold Air Inductions cold air intake and I am putting on 2" Texas Speed long tube headers this upcoming weekend. If you could shoot me over a quote breaking down the cost of the material and install I would appreciate it. Also if you could specify would brand and size cam you recommend that would be helpful as well. I am from out of town, I am about 15 minutes north of Louisville, KY. If you could provide a lead time on the install so I could plan my travels I would greatly appreciate that as well. I look forward to potentially doing business with you! Thanks, |
02-29-2024, 08:34 PM | #6 |
03-01-2024, 02:49 AM | #7 |
Dont see any lifters..... are they tossing them in for free?
03-01-2024, 06:51 AM | #8 |
Started#gottalovethatblue
It's higher than I paid in 2019, but so is everything else. That's probably not an outrageous price in today's market.
03-01-2024, 07:54 AM | #9 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Instead of getting a cam with "significant lope" you could get one with significant power gains?
Either way, you will probably need a higher stall torque converter. Last edited by gtstorey; 03-01-2024 at 05:00 PM. |
03-01-2024, 09:12 AM | #10 |
For this day and how things are cost wise, looks like a pretty good price for the job, also as stated, didn't see any lifters listed. Good luck.
03-01-2024, 10:56 AM | #11 |
Drives: 2013 SS Join Date: May 2013
That's pretty good IMO. I personally wouldn't price shop rather have a shop that knows the platform vs one that doesn't.
03-01-2024, 01:00 PM | #12 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Yes this for sure. It's the most important thing about the shop performing the work. I would look for a shop with good google reviews and not necessarily a big shop just one that you can ask questions like how long will you stand behind your work and they give a legitimate answer. Also ask them if they will pay for the labor if something goes wrong from a part that they installed. And the dyno tune is important but not a deal breaker either because you can always get an email tune from an experienced tuner on the hp tuners forum or a well know place. And like gtstorey said you will need a higher stall converter and a transmission cooler with that big of a cam.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-01-2024, 02:35 PM | #13 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
They give 23 hours for a camshaft replacement. At $2500 that only $108 an hour, That's a good hourly rate. $130-$150 an hour is common. Also I agree with others about the shop doing the work/Knowing the platform.
03-01-2024, 05:07 PM | #14 | |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I just reviewed the estimate again. No head gaskets so no head removal. I'd kinda like new/upgraded lifters with my cam especially if I'm forking over a good chunk o' cash.
