03-06-2024, 03:17 PM | #1 |
Replacing Oil Pump
After chasing some on-track oil pressure issues, going to upgrade to a Melling 10296 pump after acammer's recommendation.
What else should I do while I am in there? I realize doing probably 1/2 to 3/4 of a cam swap job, but I don't think I will go down that slippery slope right now. Is there any other recommended upgrades/updates I can do in this process?
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
03-06-2024, 05:21 PM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
You can plug the oil pan pressure relief valve.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-06-2024, 06:58 PM | #3 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
How many miles are on it?
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-06-2024, 08:01 PM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Don't think the 1Les have a relief. Isn't that only on the L99s?
Timing chain and tensioner can be changed as well |
03-06-2024, 09:05 PM | #5 |
2013 1SS/1LE
03-07-2024, 05:00 AM | #6 |
I'm not sure Joshmn my zl1 has it. I was assuming they all had it.
03-07-2024, 05:59 AM | #7 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I'm probably wrong, but I thought pretty much all the gen 4 motors have them, regardless of DOD or not. I researched this a while back and that is what I found then.
To OP, don't forget new gaskets and seals in addition to what the others mentioned. It would be a good time for an underdrive pulley.
03-07-2024, 08:03 AM | #8 |
I was going to say maybe the timing chain and tensioner but I wouldn't probably mess with it at 60k miles unless you were doing a cam swap. Maybe a good time to upgrade your harmonic balancer and plug that darn relief valve in the pan for more top end oil psi.
03-07-2024, 11:31 AM | #9 | |
And this is exactly why I didn't want to venture down the "Cam Swap" road... Initially, in my GPI shopping cart was just the oil pump. Now its: - Melling Select - High Volume High Pressure 8 GPM LS Oil Pump (10296) - PowerBond - 2010-2015 Camaro SS & 99+ LSx Truck Underdrive Pulley Kit (PBU1190-SS25) - PULLEY BOLT (OPTIONAL): ARP - CRANKSHAFT DAMPER BOLT FOR LS, GEN V LT1 AND LT4 WET SUMP ENGINES (234-2503) - MAIN BELT (OPTIONAL): SERPENTINE BELT FOR 25% UNDERDRIVE PULLEY FOR 5TH GEN CAMARO W/ ELECTRIC POWER STEERING (060780) - A/C BELT (OPTIONAL): A/C BELT FOR UNDERDRIVE PULLEY (K040350) - Chevrolet Performance LS Oil Pan 2010-2015 LS3/L99 Camaro/G8 (I figured this would be a good time to do a baffled oil pan for my road course time.) - OEM Style - Timing Cover Gaskets (12633904) - GPI - OEM Style LS2 / LS3 Timing Chain Dampener (12588670) Not for Use in Dry Sump Engines
2013 1SS/1LE
03-07-2024, 09:25 PM | #10 |
I got this guy from improved racing. I think it does the job.
03-08-2024, 10:50 AM | #11 | |
2013 1SS/1LE
