11-28-2018, 10:11 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
LS9 VS LS7 Gasket
I just placed my order for a set of the AFR mongoose heads and they are recommending a Cometic 4.160 Bore Size on their website... I had already placed my order for a set of LS9 gaskets that are showing to be a 4.100" Bore sizing.. Do I need to return these for a LS7 Gasket 4.150'' bore size? Or should i order a set of 4.160'' cometic gaskets..
Additional info if needed. 4.070' Bore, 3.622' Stroke, 6.125' Rod Length, -3.2cc Flat-Top, 1.304' CH Piston - Wiesco -3.2cc Flat-top (#10-K398X7) AFR Mongoose 260cc Heads (Recommend 4.160'') Last edited by Nighthawk89; 11-28-2018 at 10:41 PM. |
11-29-2018, 12:24 PM | #2 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Chevrolet performance 19170419 is what I run on my 427 with 6 bolt heads.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
12-01-2018, 01:20 PM | #3 |
Drives: it changes Join Date: Nov 2010
Wait til the heads arrive, and measure across the chamber
All the GM gaskets are good gaskets though |
