Old 12-08-2018, 09:08 AM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
No engine cover and I want to add a hood vent, is that a problem?
Hey guys,
I have a 2010 that I've taken the engine cover off of and I want to add the OEM hood vent (the one in the center) to my car. I can get the OEM hood vent for about $100 bucks and I don't plan on using the rain guard, but I'm a little worried about rain/snow getting onto/into the engine bay.
My question is, should I be worried though?
I remember reading a comment from someone that said the engine is sealed and all the connections are watertight so it shouldn't be something to be worried about, but obviously if it's going to be an issue I'll reconsider.
Car is a DD in rain, snow, etc.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 12-08-2018, 09:13 AM   #2
The Wanderer
Drives: Blaze Red 2014 2SS/RS
I have same vent from the factory with rain guard.... comes in handy at keeping engine bay dry especially when washing car I will always keep it in place ....
The Wanderer is offline   Reply With Quote
Old 12-08-2018, 11:04 AM   #3
xc_SS/RS
Drives: 2010 Camaro SS/RS
No need to be worried but it does take a little longer to warm up with no rain tray in the winter
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 12-08-2018, 05:55 PM   #4
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
PM me if you wanna sell rain guard....thanks
DBHWT is offline   Reply With Quote
Old 12-09-2018, 08:15 AM   #5
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
No issues here and I run a much bigger hood vent by trackspec that is fully open and no rain tray. I have ran it in pouring rain with the engine kinda wet and still runs great.
_Onyx_Wolf_ is offline   Reply With Quote
Old 12-09-2018, 11:57 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I ran the hex vents on my Camaro with the drip trays in place, no engine cover and no issues at all. Plus it helped keep the engine compartment cooler, you could see the heat waves coming out.
Old 12-09-2018, 01:07 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Thanks for the info guys!
Old 12-09-2018, 01:10 PM   #8
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Shouldn’t be an issue. Majority of everything is pretty weather tight in the engine bay form what I have experienced. I run my car with no covers on the engine since day 1. After a year I ditched the rain guard. I also removed the fiberglass hood liner underneath so it didn’t get messed up or soaked etc. I added reversed side bonnets to that pulls air in to help push hot air out of the engine bay. I can’t tell you how things are winter as I store mine in winter. As for rain I have had no issues except when I get in the rain with the car it usually leads to a full day of engine bay detailing after. I’ll post pictures for ya!
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 12-09-2018, 01:13 PM   #9
Jayjellyfish212
Drives: 2014 1LE
Covers been off for 4 years now.
Old 12-09-2018, 01:17 PM   #10
Jayjellyfish212
Drives: 2014 1LE
Universal hood small bonnets installed to draw air in. The factory center vent I wish was reversed to draw air in also.
Old 12-09-2018, 06:23 PM   #11
LCPLPunk
USA-1
LCPLPunk's Avatar
Looks sick! Thanks man!
Old 12-10-2018, 02:18 PM   #12
WoodBoss
"Old School"
Drives: 2010 2SS L99
I would not let water get into the engine compartment on a regular basis. Eventually something will corrode.
WoodBoss is offline   Reply With Quote
Old 12-10-2018, 03:00 PM   #13
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
The 14-15 OEM hood vents come with a drip tray underneath that funnels the water towards the front of the car, you should be fine as long as you have the tray as well.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 12-10-2018, 03:59 PM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
I wasn't planning on running the water deflector, but ya, corrosion is bad.
