Old 02-01-2012, 10:03 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
SS springs on a V6
I am posting this here to for hopes of some quick replies:
Morning All,
I have an opportunity to get a set of stock SS springs that I'd like to install on my V6 and have a couple of questions, # 1 being my priority.
1- Will this drop my car at all, not looking for a major drop, just a bit.
2- Will I feel any handling or comfort changes?
3- Any reason not to do this?
4- Any other benifit to doing this
FSP tuned: 377/389
Old 02-01-2012, 10:13 AM   #2
KMPrenger
KMPrenger's Avatar
I've looked into this as I considered going this route.
Car will drop some, but not as much as say, going with some aftermarket solution. Just look at an SS sometime..it should be the same as that.
Handling should improve...with the ride being a tad more harsh.
Can't think of any negative reasons to do it.
If you do this, let me know your impressions. Take before and after ride height measured on a flat surface from the ground to bottom/center of wheel well.
Old 02-01-2012, 10:19 AM   #3
Mach
Mach's Avatar
Drives: White M6 1LT RS
The search button is your friend..
I did this, so I'll chime in..
1. Your car will have the exact stance of a SS. So for a V6 its about .5 inch drop.
2. The handling is vastly superior over the V6. The ride gets a little stiffer about still much more comfortable compared to aftermarket drop springs.
3. No. Well it costs money. But I got all 4 springs and shocks for $75 off a brand new SS. Shop around. Remember you need an alignment too. That was 130 bucks for me but it came with a lifetime alignment.
4. Maybe a .25 mpg increase? Because the car has better aero due to being lower.
The only thing I recommend is get the SS shocks with your springs. The SS shocks have a different rate and they work in conjunction with the SS springs. The v6 shocks might be a little too soft.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 02-01-2012, 10:30 AM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
Thanks guys! I'm going to pass on going with just springs and look for shocks/struts and springs.
FSP tuned: 377/389
Old 02-01-2012, 10:33 AM   #5
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
Good info. Thx.
I assume buying the parts from the dealership would cost much more than vendors.
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 02-01-2012, 10:41 AM   #6
JasonK
JasonK's Avatar
Drives: 2010 Camaro
You will have to buy SS struts and shocks also. You should not use the SS springs with the V6 shocks and struts. They are cheap on ebay.
2015 Sentra / 2015 Murano / 2012 HD Ultra Classic / 1995 Z71 / 1966 Mustang
JasonK is offline   Reply With Quote
Old 02-01-2012, 10:43 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Perect, thanks!
FSP tuned: 377/389
Old 02-01-2012, 10:43 AM   #8
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
I too have debated swapping out to basically the SS suspension setup. If not that then going with Pedders.
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 02-01-2012, 10:55 AM   #9
Mach
Mach's Avatar
From what I understand SS springs fit the V6 shocks/struts.
Next mod: Done!
Old 02-01-2012, 10:57 AM   #10
Mach
Mach's Avatar
Originally Posted by Rangore View Post
Good info. Thx.
Dont buy from vendors even.. Find a member on here or ebay. It shouldn't cost more then 100 dollars for all 4 springs and shocks/struts. I got mine for $75.
Next mod: Done!
Old 02-01-2012, 08:00 PM   #11
b4z
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT
But aren't both the v6 engine and transmission lighter? Wouldn't it sit a little higher?
And why doesn't Chevy offer a version of the fe4 suspension on the V6.
b4z is offline   Reply With Quote
Old 02-01-2012, 09:38 PM   #12
Mach
Mach's Avatar
I think the RS should of came with a FE3 or FE4 suspension. But I guess the RS is a appearance package only.
Mine sits the same as a SS
Next mod: Done!
Old 02-01-2012, 09:59 PM   #13
KMPrenger
KMPrenger's Avatar
The springs are physically shorter...so it isn't the extra weight that makes the SS squat more...although theoretically there could be a very small, but un-noticeable different in high between the V8 on SS springs and the V6 on SS springs, but the difference is only about 100 - 150 lbs. Can't really make much of a difference in height because of that.
As far as offering a sportier package for the V6...I've been down this road here before and even did a poll about it. Ford offers a package for the V6 with better handling and more aggressive gearing. Wish Chevy would do that as well.
Old 03-03-2012, 09:53 PM   #14
Codeman1407
TEAM LLT!
Codeman1407's Avatar
Drives: 2010 Camaro LT
I did the Full FE3 suspension swap, and it was a pretty noticeable difference. The sways are noticeably larger, and my car sits almost 3/4" lower (see Sig). It's a good idea if you can find the parts cheap. I think soon i'll be getting some Pfadt springs to go along with it, so i think it'll be just right.
Codeman1407 is offline   Reply With Quote
Honda Civic Type RT-R Transformers Edition DarkneSS General Automotive + Other Cars Discussion 20 12-09-2011 12:32 PM
Raising/Lowering the car Rocky918 Suspension / Brakes / Chassis 28 03-18-2011 11:03 PM
Lowering springs question newagemuscle Suspension / Brakes / Chassis 17 02-11-2011 09:30 PM
Anyone Dyno Airaid on V6 running SS mufflers? faninc Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 0 12-11-2010 07:48 AM
Camaro V6 vs SS Insurance mjrebel Chevy Camaro vs... 30 04-26-2010 11:17 AM
