07-21-2009, 01:12 PM | #1 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Stock OFFSET
Okay, I did the search, I read every thread to find the answer, and I can't believe that someone hasn't given the answer or done what I would have done to help a buddy out. How about SOMEONE, ANYONE, take off one of the stock front 20's and one of the stock rear 20's and find out the answer that so many people would like to know, WHAT IS THE OFFSET of the stock 20's. Thank you very very much. :{D
07-21-2009, 03:41 PM | #2 |
Drives: the 2nd amendment home Join Date: May 2008
Some of the guys even have a set in their garage after getting wheel upgrades..... Lazy sunnybeaches
[edit] Here's what we have so far... LS, LT 18x7.5 +38mm opt. LT 19x8 +38mm SS front 20x8 +35mm SS rear 20x9 +40mm opt. SS front 21x8.5 +35 opt.SS rear 21x9.5 +40 LS/RS is the same as SS/RS all bolt patterns: 120x5xm14 Per GM Si document 2210980, lug nut torque is 100lbft or 140nm. <(thanks Pedders)
-- Benjamin Franklin Last edited by Mr Twisty; 07-24-2009 at 11:24 AM. |
07-21-2009, 06:01 PM | #3 |
2010 SIM Beige RS 6M
Drives: SIM RS 6M 66 Corvair Silverado LTZ Join Date: Oct 2008
It is published as 40mm.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America |
07-21-2009, 06:57 PM | #4 |
Can you verify it? I've also heard 35. The SS cars may also be different than the V6's.
-- Benjamin Franklin |
07-21-2009, 10:35 PM | #5 |
I have heard that the fronts are +35 mm, and the rears are +40mm. so will SOMEONE make it official?
07-21-2009, 11:29 PM | #6 |
The 19's are 35 mm.
07-21-2009, 11:52 PM | #7 |
Drives: 95 civic Join Date: Apr 2008
soo would a 38 offset fit?
07-22-2009, 01:43 AM | #8 |
Dances With Mustangs
Depends on which car you have. Do you have an SS with Brembos? Offset is primarily for clearing the brakes. Clearance also depends on the style rim you've chosen. It's usually a bit risky unless you've done a test fit, to buy a rim with a smaller offset because it might just start touching the brake calipers. Going a few mm bigger usually is fine unless you go from like a 40 to a 50, then you might start having fender clearance problems with the tire.
Only way to be sure is to put a rim on your hub and see if it clears the brakes.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
07-22-2009, 07:02 PM | #9 |
Offset is primarily for fender/inner well/strut rub.
I expect to see different offsets for different cars, ex: LS may be different that LT/RS, < may be different than SS, and fronts different than rears.
-- Benjamin Franklin Last edited by Mr Twisty; 07-23-2009 at 06:25 PM. |
07-22-2009, 08:15 PM | #10 | ||
Booooosted.
I have a set of 20" MSs sitting in my garage. What the hell is an offset? and how do I measure it for you. I'll do it when I get home in about 30 minutes. PM me to tell me you got this post. |
07-22-2009, 08:19 PM | #11 | |||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
http://www.tirerack.com/wheels/tech/...jsp?techid=101
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
07-22-2009, 08:23 PM | #12 | |
Booooosted.
Ok, so when I measure it, how can i be accurate as far as where the center is on the inside? I guess just measure the center distance and then eyeball it level from the inside. It slopes so won't be perfectly accurate. |
07-22-2009, 08:24 PM | #13 |
Booooosted.
Oh. I will lay it on the ground and measure from the floor. Should work.
07-22-2009, 08:37 PM | #14 | |
Or, It should be stamped on the wheel someplace. Look for something similar to this...
Similar Threads | ||||
3rd Gen Camaro Street Stock build thread (dialup beware) | zlathim | 3rd Generation Camaros | 9 | 12-06-2018 10:30 AM |
Camaro L99 American Racing Headers (Catted) system with stock exhaust = +42rwhp | pharmd | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 43 | 07-25-2009 10:01 AM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
Stock Offset???? | BumbleBeeSS2009 | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 06-14-2009 09:40 PM |
Wheel offset of stock wheels? | jc211 | Wheels and Tires Talk Sponsored by The Tire Rack | 0 | 03-27-2009 01:54 PM |
