Rick@Livernois
Old 01-26-2013, 12:02 PM   #1
Andymon
Andymon's Avatar
Drives: TwinTurbo 2012 IOM Camaro 2SS
2012 2SS Supercharged build
I plan on doing my first round of upgrades to my 2012 Camaro 2SS AUTO L99. My goal is for about 600RWHP weekend cruiser. I want a PD root type blower so I think the whipple would be the best option for me. Also I want the option for more power in the future. I have a list of everything I plan on throwing at the car and I am looking for feedback from forum members on my build. Please tell what I am missing and what I might want to change.
Engine:
Whipple supercharger tuner kit with 3.75 pulley
GT9 cam with dual spring kit
L99 to LS3 conversion DOD delete kit
ZR1 Head Gasket
Roto-fab whipple intake kit
Kooks 1-7/8 coated headers with catted mids
Magnaflow Street Cat-back
LPE Twin Pump kit
ID850 injectors
ZL1 MAP sensor
Dynotune
Exterior:
Nurburgring 20x10 rear with 305/35 goodyear F1 Supercar G1 tires
Nurburgring 20x8.5 front with 255/45 goodyear F1 supercar tires
Thanks for any input
Andymon is offline   Reply With Quote
Old 01-26-2013, 12:25 PM   #2
Synner
Drives: cars
Only thing I would change is go with a wider front wheel/tire. Unless you only care about going in a straight line that thing will understeer a LOT with that much of a tire size difference, especially without going to a stiffer sway to try and counteract it. Granted you could probably use the new power to create oversteer but with a lot of power that can also be risky if you're not used to driving on the edge.
I'd look at a 275 or 285.
Old 01-26-2013, 12:36 PM   #3
Andymon
Andymon's Avatar
Yes I have seen the 275 front combo on here a lot and now I know why so I will probably go that way. Thank you.
Old 01-26-2013, 01:07 PM   #4
Synner
Drives: cars
A 20x10+35 up front works and is available in a few different rotary forged TSW's and should work fine with the 285 supercar G2. Pretty sure they don't offer a 275.
The handling difference alone will be amazing. You'll have a fun ride.
Old 01-26-2013, 01:25 PM   #5
GraysonPeace
"Go on the last yellow.."
GraysonPeace's Avatar
Drives: 2010 2SS/RS L99 CGM
I have 600rwhp with much of what your planning. We also installed some better plugs and wires as well as the ARP head bolts and a trunion kit. You are also going to want to get some gauges to keep an eye on things!
Blown and built by Ty Sochacki, tuned by Jeremy Formato. Member of the 11 second club.
GraysonPeace is offline   Reply With Quote
Old 01-26-2013, 01:28 PM   #6
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
Engine:
ZR1 Head Gasket
LPE Twin Pump kit
ID850 injectors
ZL1 MAP sensor
Dynotune
Exterior:
You also need a set of hardened pushrods. Also while the heads are off you should go ahead and upgrade to ARP head studs as well
Chris
Chris-HPS is offline   Reply With Quote
Old 01-26-2013, 01:34 PM   #7
Andymon
Andymon's Avatar
I might go with Nitto NT05 275/315.
Old 01-26-2013, 01:35 PM   #8
Andymon
Andymon's Avatar
Chris
I hate to remove the heads and not get a P/P job done.
Old 01-26-2013, 01:44 PM   #9
Chris-HPS
Chris-HPS's Avatar
You have to remove the heads to change out the lifters anyway.
We can port and polish the heads.
Chris
Old 01-26-2013, 01:54 PM   #10
Andymon
Andymon's Avatar
Chris
Yes I know. Just saying might as well port them at the same time.
Old 01-26-2013, 02:52 PM   #11
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
why are you choosing thr gt9 cam?
94guy is offline   Reply With Quote
Old 01-26-2013, 02:56 PM   #12
Andymon
Andymon's Avatar
I was looking for a smooth idle blower cam.
Old 01-29-2013, 08:56 AM   #13
Andymon
Andymon's Avatar
Would any drivetrain upgrades be needed if I just ran with the whipple, intake, and exhaust?
Old 01-29-2013, 09:10 AM   #14
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
I have only done the 1st stage of the items on your list.
Haven't got to the heads/Cam part yet.
Making right at 500 to the wheels.
With the power you'll be making wheel hop and suspension stress will be a problem.
You should look into some rear suspension upgrades while the tank is out for a new fuel pump.
No reason to pay twice the labor
2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+KW V3 Coilovers
Indyblue98 is offline   Reply With Quote
