05-05-2018, 06:01 PM | #1 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Tire air compressor kit.
I don’t know if this is the right place to ask this but could someone with an SS measure the dimentions of the tire compressor/flat fixer kit that comes when you don’t have a spare tire?
Highth, width and depth. Thanks.
The Bird is the word! |
05-10-2018, 06:07 PM | #2 |
Never mind, I have it in hand and can see it is smaller than what I initially thought and will fit my needs well.
05-13-2018, 01:02 PM | #3 |
I am using it to replace the spare tire and jack in my G6 for increased trunk space when the top is down.
The GM sealant was out of date so I replaced it with a XL can of fix a flat that will only be used as a last resort if the tire plug kit does not seal it good enough..
06-20-2018, 01:08 AM | #4 |
Drives: Camaro 1997 Z/28 Join Date: Jun 2018
Good info on this thread, thanks for all the responses. One more question, if I go with the Dynaplug air compressor and plug kit, can get a separate latex sealer spray that is self pressurized that doesn't need to work through the compressor?
__________________________________________________ ______________ Who would venture upon the journey of life, if compelled to begin it at the end? Kind regards,Kasyca Diceus Last edited by Kasyca; 08-06-2018 at 05:53 AM. |
06-07-2022, 11:32 AM | #5 |
Drives: Camaro 23 Join Date: Jun 2022
hey bro, i can give you this compressor kit no problem. or I can give advice for you where you can itechcraft.com/..angular-services/ buy it
