Rick@Livernois
Old 05-30-2018, 11:16 PM   #1
SRTLOL
Drives: 2010 Camaro SS/RS 6M
Worse audio with an after market head unit
So I installed a song xav100 double din head unit with the PAC kit. I have the Boston acoustic system and after the install it seems like the bass is gone and the audio quality has gone a little down hill. I used butt connectors to make the connections and I'm thinking about reading it. And ideas on where to start? It sounds more gritty and kinda lack luster compared to when I had the stock radio installed.
"A free people ought not only to be armed, but disciplined…” – George Washington
SRTLOL is offline   Reply With Quote
Old 09-01-2018, 03:52 AM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
I've not used any of the aftermarket kits, but wanted to point out that the Camaro speaker system isn't a traditional 4 speaker system. I would assume there is some sort of adapter required to connect a traditional aftermarket HU to the stock amp/speakers.
Sounds like you simply spliced some wires and are missing some of the channels.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 09-01-2018, 06:25 AM   #3
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
What JimE stated.
You cannot swap a HU in without replacing the amp and speakers, though primarily due to the OEM "dsp". If you attempted to power the OEM speakers from your new HU, we get into connection issues (rears are bi-amped).
Snoman is offline   Reply With Quote
Old 09-01-2018, 07:23 AM   #4
Leo72793
Drives: 2011 2SS/RS
MAke sure you have the plug set to AMPLIFIED system not non amplified. IT will plug into either one. otherwise. replacement time
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers
•Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Morel Subwoofers
•Audio control LC-6.1200 6ch amp
•Helix DSP Pro
Leo72793 is offline   Reply With Quote
Old 09-01-2018, 01:14 PM   #5
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
Originally Posted by Snoman View Post
What JimE stated.
I’m not sure if this is accurate. The PAC kit was pretty much plug and play with the stock amp and speakers. The only issue I had as far as sound quality was to make sure you have it plugged into the PAC module correctly. I actually plugged mine into the NON amplified slot and all is well.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Long Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold and Missed
Current - 2011 Camaro SS, M6, black, stock
Cheap Guy is offline   Reply With Quote
Old 09-01-2018, 10:46 PM   #6
oslouie
oslouie's Avatar
Drives: 2011 Camaro 2ss
This issue has been covered. You need to plug a connector into the correct location.
Cold Air Inductions CAI, Speed Engineering 1 7/8" LT headers, Magnaflow 59959 High flow cats, Magnaflow 15089 cat-back, Dynosteve tune
oslouie is offline   Reply With Quote
Old 09-04-2018, 07:23 AM   #7
Snoman
H-Town Camaro Club
Snoman's Avatar
for some reason I was thinking non-BA set up
Old 09-18-2018, 11:57 AM   #8
Angie11
Drives: 2011 ss rs convertable
to the OP. I agree. I did the aftermarket HU with PAC and sound quality and volume were shit...all was installed correctly. I replaced the stock amp with an aftermarket amp and it sounded good again
Angie11 is offline   Reply With Quote
Old 09-18-2018, 04:45 PM   #9
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
Where did you have the connector plugged into the PAC module? A lot of people think they have it installed correctly, but don't.
I have the Scosche 2.0 kit, Pioneer head unit, BA system and stock amp. Sounds great.
Low Saturn is offline   Reply With Quote
Old 11-06-2018, 03:01 PM   #10
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
Hey sorry to bother but what kind of amp did you replace with? I had the idea to do this years ago but never got around to it. I remember there was a small amp that a lot of people used to replace the stock amp due to its size. But damn if I remember what it was.
45thCamaro is offline   Reply With Quote
Old 11-06-2018, 07:03 PM   #11
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
A popular amp replacment is the JL audio xd400/4v2. Its small and packs a punch. Fits in the stock amp location with the amp board from sub thump(er).
Technostalgia tail lights,MGW shifter, Vararam tuned intake,JDP Reservoir,Ideal MC,Tick,Elite catch can,Kooks LT, Kooks HFC,Flowmaster Outlaw,VMAX TB,Tuned by DynoSteve,Mantic 9000,DSS aluminum driveshaft,Pegasus subframe bushings,BMR trailing & toe arms,Z28 upper control arm bushings,Zl1 rear sway bar,Prothane radius arm inserts,BMR steering rack bushing,Goodridge brake lines,Ridetech HQ level 2 coilovers,3.9gear,Trutrac,billet caps,1k axles,1LE diffuser,Havoc spoiler,SSclones,20in CCW 505A,Continental Extreme Contact Sports
Black_SS10 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
