Old 09-14-2018, 06:14 PM   #1
Camaro2010FL
Drives: 2010 Chevy Camaro
Camaro 2010 oil pressure
Is it normal when driving your camaro (2010) for the oil pressure to go all the way up to 70? It recently had an oil change and I’ve never seen it go that high. There was a problem with that visit and the issue was fixed but I’m thinking something else must’ve went wrong. Can someone help.
Thanks
Camaro2010FL is offline   Reply With Quote
Old 09-14-2018, 07:20 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
When the oil is cold,as in first startup the pressure will be higher than "normal". When the oil is at operating temp it will have,show less pressure. None of which is cause for concern. Low or no pressure is problematic.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-14-2018, 08:58 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
New, cold oil will be thicker and give higher pressure. No worries...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
